Twin Turbos and Coolant Temps
Old Feb 19, 2012 | 04:25 PM
f150intally's Avatar
f150intally
Default Twin Turbos and Coolant Temps
What do you guys see on a regular basis during a combination of normal and spirited driving? I routinely see temps between 190 and 210. Is this common? Seems a little warm but I didn't have a coolant gauge before the turbo install. Running the GTM Stage 2 with stock cooling system.
What do you see on your FI setup?
Old Feb 19, 2012 | 04:59 PM
GreenGoblin's Avatar
GreenGoblin
Seems right with in the normal range.
Old Feb 19, 2012 | 06:25 PM
RED RIDER's Avatar
RED RIDER
absolutely normal....The highest I have seen at sustained speeds ( Big bend open road race, no thermostat, koyo radiator) was about 215*...this was running ~ 135-140mph for 59 straight miles...April is fast approaching I can't wait to run again!
oh and btw.. My Z has greddy twins, all supporting mods and is currently 550 at the tire
Old Feb 19, 2012 | 06:30 PM
f150intally
I have seen mine in the 215 range, nearly 220 but that is not cruising at 60+. Just driving in stop and go traffic after spirited driving.
Old Feb 19, 2012 | 08:04 PM
R350Zz33's Avatar
R350Zz33
stop and go is bad for cooling
Old Feb 20, 2012 | 04:30 PM
Mike@GTM's Avatar
Mike@GTM
Those coolant temps are normal...even for a stock Z.
Old Feb 20, 2012 | 05:04 PM
djamps's Avatar
djamps
I have the GTM (PWR) radiator and rarely exceed 200f. Never measured it when stock..
Make sure both fans are blowing properly, there was a recall on the motors.
Old Feb 20, 2012 | 05:37 PM
eltness350's Avatar
eltness350
The Untouchable
normal temps, u could do the pathfinder coolant mod also if you are worried, search it if u want
Old Feb 20, 2012 | 06:05 PM
f150intally
I didn't think the pathfinder mod was applicable on HR motors. I watched it today and it was around 195 to 205 on the way home. I think its fine. Both fans were blowing when I let it idle for a few minutes in the garage.
Thanks for all the replies.
Old Feb 20, 2012 | 06:08 PM
f150intally
Are you running stock fans? I had a custom C&R racing dual pass radiator on my SR powered S13. It was amazing.
Old Feb 21, 2012 | 04:02 AM
djamps's Avatar
djamps
Stock fans, yes. In fact, my original fans were both blown (spinning about 5rpm basically LOL). Even then, I never went above 215 sitting still in scorching weather. With new (stock) fans it never breaks 200, and now my A/C works again
Old Feb 21, 2012 | 06:36 AM
aln's Avatar
aln
Not sure if this might be of interest, but I'm seeing below temps. Thats from start and 2.30min+
(in my mind it's not great temps...)
That's on track.
Old Feb 21, 2012 | 07:30 AM
f150intally
I really think these cars just run warmer than we are used to. My buddy's TT HR almost mimics my temps exactly. Pretty normal I guess to see 195-210 Fahrenheit during any type of driving.
Old Feb 21, 2012 | 11:43 AM
binder's Avatar
binder
that's not abnormal for any car.
Old Feb 22, 2012 | 10:59 AM
f150intally
I suppose. I just got use to my last turbo car running much cooler but it was a dual pass radiator.
Old Feb 22, 2012 | 07:55 PM
binder's Avatar
binder
it shouldn't be running much cooler. You lose efficiency when running an engine that cool. That's why thermostats are set to open after 180*.
Old Mar 2, 2012 | 04:25 AM
nathanwl2004's Avatar
nathanwl2004
+1 on what binder said.
Old Mar 2, 2012 | 09:14 AM
SE5spd's Avatar
SE5spd
Yup that's normal. After 25 minutes on a road course my temps are only at like 200-210
I see 220 every once in a while but that's sitting in traffic and as soon as it hits 220 the fans kick in and it instantly drops back down to like 180-200 range.
SharX59
Sep 27, 2015 09:23 AM
