VQ35DE vs VQ35HR time attack engine
Old Mar 15, 2012 | 09:00 PM
ace32x's Avatar
ace32x
Originally Posted by Alberto
Let us know if you ever run it.
i ran mine at 298, did a 13.4 @ 111
Old Mar 15, 2012 | 09:30 PM
Viksz33's Avatar
Viksz33
Check out s&r performances hr single turbo kit if you decide to go the hr route
https://my350z.com/forum/shop-builds...-it-all-6.html
Old Mar 18, 2012 | 07:30 PM
junglefever's Avatar
junglefever
Thanks for the input guys. I am steering towards the HR for its ease of packaging with the inlet pipework, easy to run the pipework from one turbo to the inlet on the other side after passing through the cooler. Changing the phase of the cams for maximum response is very appealing.
It will be run by a Haltech so no issues there.
DaveJackson- yes they are in a G35 if someone has imported one but they are rare as rockinghorse sh*t.
I could only find 2 DE motors from a bunch of wreckers here in Brisvegas and they have the original box so it's also cheaper for me to buy a CD009 and ship it here.
I haven't read any oil surge/starvation issues with just the addition of a pan spacer- do you guys run traps doors to prevent this??
Also where do take the oil pressure feed for the turbo' from? I've only found one picture and it looked like it was tapped from the oil pressure sensor on the passenger side and then run under the block for the driver side turbo- is that correct or do you tap into the block?
Thanks for the replies!
Old Mar 19, 2012 | 12:49 AM
racer59's Avatar
racer59
Hi i have built both de and hr with a single turbo in a track car the hr gets my vote the de made 650hp at 18psi and the hr made 750hp at 15psi on e85 and the hr loves to rev.
where in aus are u i have a 2008 hr motor with 300 km sitting on a pallet
Old Mar 20, 2012 | 02:56 AM
junglefever
In Brisbane. PM me with a price and what comes with the motor.
I was leaning towards the HR due to the longer rod/revability and reduced side loads. Only had a few concerns. Would the OEM bearings be ok at that power level. Could i leave the head standard other than new springs and retainers. With around the 500rwhp target i wanted to be sure the standard head would flow enough. But looking at the lift and duration i suspect it won't be an issue?
What pistons & head gasket did you use in the HR?
I was looking at contacting Mahle to see if they had made any.
Cheers
Old Mar 20, 2012 | 04:20 AM
snobes's Avatar
snobes
I think most consider the stock HR to hold 500whp fine, and just use an OEM HR headgasket if you do build, its fine at that power level.
Old Mar 20, 2012 | 05:11 AM
junglefever
Thanks. I'm going to change the pistons and rods mainly for added protection against detonation and slightly lighter rotating assembly.
Cheers
Old Mar 20, 2012 | 06:33 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Terrible time. Good trap.
Old Mar 20, 2012 | 07:28 AM
ace32x's Avatar
ace32x
ya im not to great at launching and bad track prep and mediocre tires didnt help either.
Old Mar 20, 2012 | 07:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
That's the second highest trap I've seen NA though. Not too shabby.
Old Mar 20, 2012 | 07:34 AM
ace32x's Avatar
ace32x
had good shift from second to third
Old Mar 20, 2012 | 10:10 PM
junglefever
Thanks.
What pistons have people used if they're replaced internals? Rods seem to be on offer but pistons are a "custom" make. Just interested - i was looking at getting some Mahle's made.
Old Mar 26, 2012 | 05:36 AM
junglefever
Got my answer on the pistons, have one more though...
Been reading about the CD009 gearbox with it's tripple synchro's etc.
With my 2008 VQ35HR I've read that there is a HR version of the CD009 is that correct? Or do i just get one of these?
Thanks
http://www.conceptzperformance.com/C...9124.150.67.52
Old Mar 26, 2012 | 05:50 AM
djamps's Avatar
djamps
HR gearboxes are all CD009+. That said, DE and HR gearboxes are totally different. Not only do the bell housings not mate up but the HR uses a crappy concentric slave cylinder. The first couple years of production they had all kinds of issues with the slave cylinder..which unlike DE requires dropping the whole tranny to get to.
Old Mar 26, 2012 | 07:21 AM
ace32x's Avatar
ace32x
this ^ so when you do it get a zpseed heavy duty csc with your clutch choice
Old Mar 26, 2012 | 04:52 PM
junglefever
Thanks guys, i had already got the heavy duty CSC on my order, i was just concerned about the gearbox that listed its part as JK40 and not CD009.
I gather it's a new naming code with the CSC and different bell housing- are the internals still the same??
Thanks again, about to place my order with conceptperformance.
Old Mar 27, 2012 | 06:06 AM
str8dum1's Avatar
str8dum1
its not the same transmission, so its not going to be a CD009
Old Mar 27, 2012 | 05:15 PM
  #38
junglefever
Thank you
Old Mar 27, 2012 | 05:18 PM
  #39
ace32x's Avatar
ace32x
checked TB's for you today theyre 2.75"
Old Mar 27, 2012 | 06:41 PM
  #40
djamps's Avatar
djamps
Didn't mean to imply it was a CD009. What I meant was that it has the same syncro improvements/upgrades the CD009 had over the earlier versions.
