Another Vortech Build
Old Mar 23, 2012 | 11:01 AM
jpc350's Avatar
jpc350
Yes, would strongly suggest the GTM pulley mod...Extra protection against belt slip....Cost effective ..
Old Mar 23, 2012 | 07:17 PM
lillong1991's Avatar
lillong1991
ok cool, i'll order it next week then. do you have the kit with the one or two extra pulleys from GTM? also, What kind of power did your car make?
Old Mar 23, 2012 | 09:35 PM
lillong1991
More parts came in today, heres some more pics:
928 Motorsports 3.00 6 rib 20mm pulley:
Ribbed pulley to reduce belt slip:
Walbro 255 fuel pump:
NGK spark plugs:
Old Mar 24, 2012 | 06:45 AM
str8dum1's Avatar
str8dum1
that pulley was machined to fit the VQ bracket, correct?
Old Mar 24, 2012 | 07:56 AM
jpc350's Avatar
jpc350
My last tuning session ended up with 405 Hp and 320 tq. Since then I added the 2.87 pulley, GTM pulley mod and IIRC the 34 cog pulley...Not completely sure of the 34 cogger.. Power numbers ?? Not sure what is meant by one or two extra pulleys.. I have 1 GTM pulley and it came with a Bando belt..
Old Mar 24, 2012 | 07:08 PM
lillong1991
GTM has two kits available that are supposed to prevent belt slippage. both come with the bondo belt. however one comes with two extra pulleys and one comes with one extra pulley.
GTM duel pulley kit:
GTM single pulley kit:
Old Mar 24, 2012 | 07:10 PM
lillong1991
Yes, They are direct fitments to vortech supercharger kits. I talked directly to their sales department and if you look on page one a member names "threads" has one of their pulleys on his car. here is a picture of the installation instructions that 928 motorsports provided:
Old Mar 25, 2012 | 08:26 AM
jpc350's Avatar
jpc350
Yea, the second lower pulley doesn't look like it's adding any significant friction over the single pulley...
Old Mar 25, 2012 | 09:08 AM
lillong1991
Yeah i agree. Ill have to call up GTM and talk to frank hill and see what they both say about it
Old Mar 27, 2012 | 08:14 PM
350z006's Avatar
350z006
Welll...they will fit with the Vortech shaft, but they may not be aligned properly, well at least that's the way it was with my 2.75 from 928 Motorsports...I had to machine mine similar to this...
https://my350z.com/forum/8268917-post2.html
but I do have a Revup Vortech kit though...maybe you'll be ok...
You may want to ask Threads, see if he did have to make any mods to get his 928 pulley to fit...
Old Mar 27, 2012 | 10:11 PM
lillong1991
If you look on page 1 of this thread, THREADS commented and told me that they were a direct fit, however i might need a spacer to get it to fit properly.
Old Mar 28, 2012 | 05:37 AM
Threads's Avatar
350z006's post is now making me question whether or not my pulley needs/needed machining. I'm almost 100% sure the 928M pulleys are not machined specially for VQ brackets.
With all that being said, my pulley has been spinning strong for about ~1000miles with no issues(including no-to-minor belt slip). The only modifications I've done was shortening the pulley key and adding thicker spacers between the shaft bolt and pulley (to compensate for the lack of extra space that's included on the stock Vortech pulley).
Old Mar 28, 2012 | 06:40 AM
05Z33's Avatar
05Z33
I would try to avoid machining the pulley. I had this done and it weakend the integrity of the pulley causing it to fracture. What you should do is shave down the lip that faces the pulley on the bracket using a dremel.
Old Mar 28, 2012 | 12:43 PM
- bigc -'s Avatar
- bigc -
^ to be clear, are recommending that folks shave down the lip on the jackshaft, correct?
Old Mar 28, 2012 | 01:27 PM
05Z33's Avatar
05Z33
Yes, that is correct.
Old Mar 28, 2012 | 06:57 PM
lillong1991
Im gonna be honest with you guys, i'm just gonna give the puley to frank and tell him to do whatever he want to make it fit. i am more then confident that he will know exactly what to do with it to get it to fit perfectly.
Old Mar 28, 2012 | 07:26 PM
350z006's Avatar
350z006
I'm sure Frank can handle that...most decent shops can...
Old Mar 28, 2012 | 08:14 PM
  #38
lillong1991
have you ever been to hill's?
Old Mar 29, 2012 | 03:57 AM
  #39
wizard's Avatar
wizard
Originally Posted by Threads
Yes. I run the 2.62 pulley on my setup. Just make sure you get the right rib/size for our applications.
Upon installation, it might be handy to have some sort of heat source to heat the pulley up prior to installation. They fit very tight onto it's mounting point. As well, I had to trim my pulley's key because the pulley is slimmer (doesn't have the excess on it like the Vortech pulleys do.
Sorry this is slightly offtopic, but how much power are you making with the 2.62. Not many people running that size pulley on the VQ? Is yours stock DE?
Old Mar 29, 2012 | 06:15 AM
  #40
Threads's Avatar
No worries. My setup may be found here:
https://my350z.com/forum/forced-indu...-v3-setup.html
