MT single turbo build....
Old Apr 1, 2012 | 10:28 PM
  #41
Flo-ridaZ33's Avatar
Flo-ridaZ33
Originally Posted by Cass007
CAUTION: Blatant Attempt to ***** Parts
I've got a Carbonetics Twin in my garage collecting dust. PM me if you are interested.
DAmn you!
Old Apr 1, 2012 | 11:18 PM
  #42
dj lizard's Avatar
dj lizard
^ hahahahahaha lmao
Old Apr 2, 2012 | 04:35 AM
  #43
konrad's Avatar
konrad
Make sure the APS kis is the external WG kit, otherwise you will get back pressure problems and won't make more than that momentum kit.
The only single turbo kit out there capable of making 700+ whp is the Boosted Performance kit
Old Apr 2, 2012 | 06:00 AM
  #44
binder's Avatar
binder
Originally Posted by binder
on race gas i think he was in the 700hp but going from 700hp to 800hp is a huge step. I haven't seen a gt40 break 800hp on a 3.5 liter engine. 700hp is doable on race gas but that's not 800hp
Originally Posted by Resmarted
Ive never even heard of a gt40 making 800whp... on a 2liter im sure its possible but yeah not happening on a 3.5
i'm confused at what you are saying. You repeated exactly what i said.
Originally Posted by dj lizard
So any recommendation on what I have to do on the kit or anything else ??????
ask Jason aka Blkbird on here. he had an APS extreme before he changed to GTM kit. I think he was only mid 600's with the APS extreme and he had a very extensive build.
Don't mess with that veyron pump junk. Way too much money for something that doesn't perform as it claims. Someone posted the flow rates in another thread (i think it was resmarted) and as the pressure goes up (as it will with a boost referenced regulator) the veyron pump fell on it's face with flow rates. If you are going to go race gas you could probably get away with walbro 400. No way e85 will push a single pump to 800hp. Twin pump will be required then.
Old Apr 2, 2012 | 12:03 PM
  #45
dj lizard's Avatar
dj lizard
ok so welbro 400 it is... there is no way I will be tuned on e85 since its not
available anywhere near.... the kit already have a 3.5 downpipe with external WG,
and dump tubes...
the only thing I'm concerned about in my exhaust "I'm running AP single exit."
which means I would have to get a Y-pipe. would it be too much restriction???
Old Apr 2, 2012 | 12:12 PM
  #46
ace32x's Avatar
ace32x
and dump tubes...
it might be, you should just get a cutout
Old Apr 2, 2012 | 01:23 PM
  #47
binder's Avatar
binder
There is a chance it could be too restrictive. If it's a 3" straight through it might not be but who knows. I will be selling my 3" SP boost activated cutout soon. I have 2 actuators for it as well. 7psi and 11psi so choose when you want it to open. Gained me ~150hp over just my restrictive exhaust on it's own. Won't be as much gain with a freer flowing exhaust but it will still probably gain some good hp.
open dumps help with removing the volume of exhaust going through the system so less backpressure. I assume "dump tubes" meant open dumps.
Old Apr 2, 2012 | 02:36 PM
  #48
dj lizard's Avatar
dj lizard
good stuff thanks for the input... yes it's an open dump pipe that's what I meant...
so for now I will be running a 3" y-pipe for with in the break-in period, then either
build a 3.5" turbo-back... or an actuated cut-out with the 3" Y-pipe.
will for this build I'm wishing " no expectation here since I have no idea where it will take me"
700whp is enough power "with less lag".
so it's only a matter of waiting for the kit to show up and the few missing parts such as
the pump/Ypipe/etc...
lets see where this build goes...
Old Apr 14, 2012 | 01:17 PM
  #49
dj lizard's Avatar
dj lizard
So, here we go.... engine is out of the car and just transferring all the harness, sensors, accs. too....
got couple of questions....
1. which break-in oil should I use... I read a lot about it on the forum and it never been a single straight out answer... I did speak with the tuner and he told me we are doing a 30mins. idle"break-in tune"/oil change 500mile/oil change 1000mile and then retune
but my question is which oil should I be using "I know I have to rune non-synthetic but which type???"
2.Is it possible to fit gt30r's using the APS extreme manifolds??
if it is..... which A/R,housing size show I run???
Note: I did change the type of injectors to ID1000cc since I have heard a lot of good stuff about them....
Old Apr 17, 2012 | 06:45 AM
  #50
binder's Avatar
binder
as for break in oil. Any quality 10-30 or straight 30w oil should work. Mine has varied over the years but the last 2 engines I used mobil 1 10w30 for my break in and I added redline sythetic break in additives (zinc and phosphorus additives).
I, too, do the first oil and get it out fast, then do another one around 500 then at the 1000 mark I switch to my sythetic.
Old Apr 17, 2012 | 07:04 AM
  #51
dj lizard's Avatar
dj lizard
good good great.... one point knocked out... now the gt3071r twins is it possible or not I'm just cruise to know if it fits or not ??? I know GTM manifolds are longer and the turbos located further back..... now is there a turbo housing small enough to fit??? I know I read somewhere that one of the gt28 housing is interchangeable with the gt30???? I don't know if it's 100% true....
Old Apr 17, 2012 | 09:29 AM
  #52
str8dum1's Avatar
str8dum1
you will not fit true 3071s. lots of places can machine the housings to fit the bigger wheels. Cass had that done. you will not fit a real 3071 in there though
Have you already bought the APS extreme? If you are wantin to change out the turbos already,I wouldnt buy that kit. rpelacement parts are next to impossible to get.
If I was doing it again, it would be a BP kit with a 7175 with a big AR (ha just kidding, more like a 8288 with a QSV )
Old Apr 17, 2012 | 10:34 AM
  #53
dj lizard's Avatar
dj lizard
I have already bought the kit.. I'm stuck with what ever I have... I'm not the luckiest man on earth as you see lol... first started working with functioned:tuned "out of business", then Momentum kit "out of business", and finally APS hahahaha how funny... will will machining the housing and fitting a bigger wheels gives in HP gains if not then why doing that..
Old Apr 17, 2012 | 10:53 AM
  #54
str8dum1's Avatar
str8dum1
ahh just seemed like a super short time period between when you were looking at a momemtum kit and now.
did you buy it new or used? If used, you probably want to send the turbos off to get inspected. Its not easy having to pull them once installed if they are bad.
Post 40 already says they are gt30 turbos. There's nothing more you can do.
Old Apr 17, 2012 | 11:03 AM
  #55
dj lizard's Avatar
dj lizard
I sill have both of them MT and APS... turbos are off to be inspected.. that's why I thought why not raise the bar a bit and go with the gt30's if they were out.
Old Apr 17, 2012 | 11:31 AM
  #56
konrad's Avatar
konrad
Pm glex25 he had his standard APS turbos rebuild and upgraded, i think the only thing you can do is get billet wheels
Old Apr 17, 2012 | 11:37 AM
  #57
Resmarted's Avatar
Resmarted
LOL
@Binder I just was agreeing/backing up what you said.
Old Apr 20, 2012 | 01:44 PM
  #58
binder's Avatar
binder
Ic, I was confused
Old Jul 29, 2012 | 04:11 AM
  #59
dj lizard's Avatar
dj lizard
Bringing this thread back from the dead with the dyno results...
So after going throw the B.S. with APS tt, I ditched it and went back to the momentum kit.
I did rotate the down pipe and converted the waste-gate to open dump... since it didn't
lineup at first...
Anyway here is the build list I ended up with:
Momentum kit GT3582R with the headers.
ID 1000cc injectors.
Built engine "info in page#1"
AAM stage 2 return fuel system with rails "the custom one I had leaked from every where"
welbro 255lb
it made 517.8/462.8 15psi on DD 93F was the temp.
here is the vid
Old Jul 29, 2012 | 12:20 PM
  #60
DaveJackson's Avatar
DaveJackson
Master
Neat. That sounds high for the size of fuel pump that you mentioned. I am probably wrong, but I thought I recalled people saying that the Walbro 255 would be running out of steam at that rate.
