FS: 52mm nitrous pressure gauge
Old Apr 16, 2012 | 01:42 PM
shydork808's Avatar
shydork808
Default 52mm nitrous pressure gauge
i have an Elite 10 Color 1600 PSI Nitrous Pressure Gauge. the gauge is a glow shift and works 100% fine. i stop spraying and upgraded to a supercharge and no longer need the gauge. this is just the gauge it self does not include any of the wiring. $50 dollars shipped plus paypal fees.
Old Apr 18, 2012 | 01:53 PM
AntKneeGrod's Avatar
AntKneeGrod
do you have all the wiring that goes along with?
Old Apr 18, 2012 | 02:21 PM
shydork808's Avatar
shydork808
No, there is no wiring that comes with the gauge. The gauge works fine it just doesn't have the wiring.
Old Apr 19, 2012 | 08:18 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
What kind of sending unit needs to be used with this gauge in order to hook it up and use it?
EDIT: Do you have the 3 items circled in red that usually come with this gauge to make it work?
Old Apr 20, 2012 | 04:03 AM
shydork808's Avatar
shydork808
It's just the gauge man. No wiring
Old Apr 20, 2012 | 07:21 AM
TurboTom's Avatar
TurboTom
can you buy all the other components seperatly off of their website?
If not then how would one go about installing this?
Old Apr 20, 2012 | 09:33 AM
shydork808's Avatar
shydork808
You'd have to check on the glow shift website to find out, but I'm pretty sure you can get all that stuff from them
Old Apr 20, 2012 | 04:39 PM
SparkleCityHop
Living in 350Z
I found the nitrous sensor needed:
Elite Nitrous Pressure Sensor $50
http://www.glowshiftdirect.com/Repla...re-Sensor.aspx
But the only way that I found to get the Gauge Power Harness and Sensor Harness was to buy the entire gauge:
Elite 10 Color 1600 PSI Nitrous Gauge $110
http://www.glowshiftdirect.com/elite...ure-Gauge.aspx
OP, what happened to the harnesses and the nitrous sensor? Are you sure you can't find it? If you have the two harnesses, it would definitely make it easier for me to buy this. Otherwise, I can't find a way to make it work.
Thanks!
Old Apr 20, 2012 | 04:57 PM
shydork808's Avatar
shydork808
I still got all the wiring on my car. I swapped the gauge inplace for my boost gauge and just tapped into that harness to power my new gauge. Like my nitrous kit is still for the most pArt on the car minus a few things since injust put my return system and procharger on
Old Apr 20, 2012 | 05:17 PM
SparkleCityHop
Living in 350Z
That's cool. If you decide to take the stuff out and sell the sensor and two harnesses with it, PM me and let me know. I'm liking those gauges for the orange color match and may pick a few gauges from them. Was the orange pretty close to the stock orange gauges?
Thanks & GLWS!
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
