Catch can recirculation fail. Blew front crank seal on first boost pull
Old Apr 24, 2012 | 11:33 AM
str8dum1's Avatar
str8dum1
^exactly, no reason to even fuss with a catch can when it vents to your exhaust.
Old Apr 25, 2012 | 08:37 AM
binder's Avatar
binder
although plumming into my exhaust would be nice i don't think i'm going to do it. That would require a long hose run halfway down the car to meet post turbo exhaust.
I'm going to open up the 3/8" vents between the 2 valve covers since they are the biggest of all the valve cover vents and run those down to the bottom of the engine bay so the smell stays out of my cabin. i think that should be sufficient.
Old Apr 25, 2012 | 11:04 AM
rcdash's Avatar
rcdash
A long run of hose is itself a restriction (if narrow)... Might want short, thick hose to a catch can, then longer hose from the can to dump wherever you wish.
Old Apr 25, 2012 | 11:34 AM
bmccann101's Avatar
bmccann101
subd.. wonder what theyre building me to avoid this.. i dont want to be leaking anything at all. or blowing things out.. eesh.
SOunds like prison. haha.
Old Apr 25, 2012 | 12:23 PM
str8dum1's Avatar
str8dum1
^probably nothing if you didnt specifically ask for it.
Old Apr 25, 2012 | 12:27 PM
bmccann101's Avatar
bmccann101
id assume youre right.
Is this just not commonly talked of maybe just becuase high boost vehicles are less common?
Id assume ppl would have been all over this topic at some point otherwise..
if i go with a small non vented catch can w no special check valves, and just connect at the plenum like usual, shoudl i be good to go? Not trying to steer away from the topic of course, just asking the advice/input.
Old Apr 25, 2012 | 02:17 PM
djamps's Avatar
djamps
I don't think there's any inherent issues with standard setups in high boost...it's just that binder's custom smell reduction system apparently has issues..
Old Apr 25, 2012 | 02:28 PM
bmccann101's Avatar
bmccann101
haha , nice.
Old Apr 25, 2012 | 02:29 PM
rcdash's Avatar
rcdash
^ the stock PCV can stick, restrict and/or let boost in, so...
Safest and easiest is just breathers on all the ports. Done. Smelly but done.
Old Apr 25, 2012 | 05:41 PM
str8dum1's Avatar
str8dum1
i dont use anything special and i run some boost.
breather on drivers side, vented catch can on the passenger side.
Old Apr 26, 2012 | 05:18 AM
konrad's Avatar
konrad
I just got 2 beathers on each valve cover, with drilled out pcv. No problems at all
Old Apr 26, 2012 | 06:07 AM
str8dum1's Avatar
str8dum1
^ your build done? dyno'd yet?
Old Apr 26, 2012 | 06:33 AM
konrad's Avatar
konrad
I was refering to my old build. I'm waiting for my machine shop to finish my heads
Old Apr 26, 2012 | 07:20 AM
4SHIZZIL's Avatar
4SHIZZIL
this is what I have.
I had a bad motor at one point, bought a OEM recalled one and this helped big time.
now its the default set up
Old Apr 27, 2012 | 08:28 AM
binder's Avatar
binder
just found out (since i'm not home) that those center connecting ports on the valve covers are 1/2" and full opening (unlike the drivers side). 1/2" hose should flow plenty!
exactly
This never caused me issues except smell so go with this. I was just looking for a better utopia of driving without being intoxicated on fumes. After my 3hr drive home I have a major headache for a few days.
Old Apr 27, 2012 | 09:11 AM
str8dum1's Avatar
str8dum1
wonder why your car still smells even with recirc air on.... i did 12 hrs with the GF and she didnt even notice anything.
are you driving with the windows open? When i had just turndowns after the turbos right under the seats, with the windows open, it would billow the fumes into the car when driving... Sure you dont have an exhaust leak?
Old Apr 27, 2012 | 09:17 AM
binder's Avatar
binder
This is windows up. Windows down or with the vent system off is the only way I don't get fumes. So if it was a leak then I would be getting it with windows open i would assume.
I've checked everywhere for leaks though. I was afraid i had a preturbo leak slowing me down and nothing so far. I fixed all those issues. My cutout might be leaking slightly but it's behind the driver and passenger seat so none of that exhaust should be able to make it's way back up front to the engine bay to be sucked in.
IDK.....car is killing me these last few days with that stupid seal issue. Know any good way to get smoke pressurized inside of the exhaust? I could try that to see if there is a header leak that i can't hear or feel with my hands when the car is running.
Old Apr 27, 2012 | 09:46 AM
  #38
str8dum1's Avatar
str8dum1
i smoked my car by just plugging the exhaust when i was looking for an exhaust leak. didnt see any so I dont really know if those smoke machines the garages have pressurize enough. I know my cutout was smoking like hell though, and had to plug that to continue the test.
but windows up, recirc air (vent off) = no fumes.... thats the same way my car is. I can not use fresh air. So your car is the same as mine then.
Old Apr 27, 2012 | 10:02 AM
  #39
binder's Avatar
binder
hmm, i just don't know how to make good smoke. I have a great port in my downpipe for backpressure testing i could use to put smoke into the system. Just don't know how to make good smoke (concentrated).
Old Apr 30, 2012 | 02:48 PM
  #40
binder's Avatar
binder
Ok, tried top take the pulley of to replace the seal today with no luck. While I was messing around I saw that the seal blew out of the timing cover so it definitely was a pressure issue. I put it back into place and no more leak. Tomorrow I'll test it under boost before I replace the seal. I opened my breathers back up.
I'll post pics of it later when I'm on the computer.
