P0011 code
Old Apr 23, 2012 | 04:16 PM
Zphanatic's Avatar
Zphanatic
Angry P0011 code
Hello everyone. Im having an issue with my car, its got a built motor with greddy kit. I did research, but everyone seems to get it the p0021 code as well, which is the other bank. I only get the p0011. It stutters and sputters mid-range, anywhere from like 3k-4k. So the code is p0011, which is related to the cam sensor/vvt/timing, etc. I've had this code before and it would make my car run like described above. First time, I tried swapping vvt's, cam sensors, crank sensor, and EVEN pulling the front timing cover off to see if it jumped timing. Didnt come back for another couple months. Came back a second time. So once again tried the above and pulled front timing cover AGAIN. Both times, it was timed correct, nothing wrong at all... Then I rebuilt the motor for a little more power. Now its back again for the 3RD TIME! I dont wanna pull the front timing cover off again, especially after doing it twice before. And its intermittent. Sometimes its fine, sometimes its not. The only other thing I can think of, is getting a new engine harness.
Anyone have any other ideas??? Or had this issue before? It just came out of nowhere. Car has been running for at least 4 months with no issues. And now this code is back...
Old Apr 24, 2012 | 10:40 AM
str8dum1's Avatar
str8dum1
the FSM only list 3 possible causes for the passenger side IVT control...
> Crankshaft position sensor (POS)
> Camshaft position sensor (PHASE)
> Accumulation of debris to the signal pick-up portion of the camshaft
it shuts off cam timing, thats why the car feels funny in the midrange because thats where the cam should be most advanced.
Start with those 3 things.
Old Apr 24, 2012 | 08:41 PM
johnwigs's Avatar
johnwigs
you have to data log to figure out why it is setting the code
int/v tim: will give you in degrees amount of "corrected angle"
int/v sol: gives what the ECM is commanding the solenoid to do
if int/v tim is anything other than 0* (+/-1*) at idle then there is a base timing issue/electrical input error
if int/v tim does not change when you poke the throttle and ECM is commanding the solenoid to advance then it is wiring/solenoid/cam sprocket
Old Apr 25, 2012 | 06:45 AM
str8dum1's Avatar
str8dum1
^ are you logging that with cipher?
Old Apr 26, 2012 | 03:08 PM
Zphanatic's Avatar
Zphanatic
I had a nissan guy plug up the consult III. With key on, engine off, bank 1 and 2 are at 0. With the engine on, bank 1 (passenger) read -14 degrees, bank 2 fluttered like 1-2 if I remember correctly. This was at idle. When revving bank 1 stayed at -14. So I disconnected the cam plug while engine running and consult III connected, still stayed at -14. So like said above, it has to be electrical.
But I also tested for ground and power. I also did a continuity test for the signal wire, and it was fine as well. 0 ohms too...
Any other ideas???
Old May 15, 2012 | 11:50 AM
mgrotel's Avatar
mgrotel
im getting a p0011 as well, any other ideas would be appreciated.
Old May 18, 2012 | 03:07 PM
binder's Avatar
binder
i would replace the sensors.
the sensors seem to be intermittent when they are starting to go bad. I know mine was hit or miss for almost a year before it finally failed.
Old May 18, 2012 | 05:34 PM
mgrotel's Avatar
mgrotel
the p0011 is only every so often, not all the time
also getting a p0335 every so often too
Old May 19, 2012 | 10:32 AM
binder's Avatar
binder
probably the sensor on it's way out.
Mine would be fine for a few weeks then all of a sudden it wouldn't start and throw that code. I didn't do anything at all and it would just randomly fire up after a couple of hours. Continued to do this off and on until i just replaced hte sensor.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
