Vortech V3 build begins
Old May 26, 2012 | 06:06 PM
  #101
lillong1991's Avatar
lillong1991
Originally Posted by unvmyg35
How much boost are you pushing?
I believe it hit 12.5psi. I will put a boost and A/F ratio chart up as soon as i can
Old Jun 4, 2012 | 02:54 AM
  #102
Jamaica2G's Avatar
Jamaica2G
Thought you were staying away from 10+?
The video shows you guys were about dead even - too much traffic IMHO. Where's the nearest track?
Old Jun 4, 2012 | 07:35 PM
  #103
lillong1991
I was gonna but the psi number doesn't really matter. Its the TQ number that matters the most and it only hit 363wtq. Plus i won't hit max psi unless i push the car past redline which i don't do much.
Yeah it was very close. and the nearest track is like an hour away. apparently were not allowed to post street racing videos on here even though mostly everybody on this site talks/ participates in it with their car. who would have though? haha
Old Jun 21, 2012 | 07:01 AM
  #104
Calinismo350z's Avatar
Calinismo350z
nice.. I'm about to upgrade my pulley to a 3.12 however I do have a some questions don't know if you guys an help. I'm not planing on going over 400whp now I've seen guys that are pushing around 380 to 400whp with the basic bolt ons witch is full exhaust, intake pletnum and of course a good tune. now my question is, would I really need to upgrade the MAF sensor and injectors? I know If I don't I'll prob be maxing out both the injectors n MAF but I don't really go WOT that often. what u guys think?
Old Jun 21, 2012 | 07:16 AM
  #105
Exemption's Avatar
Exemption
if you plan to just stay a little less than 400 whp then yes to injectors no to the maf. At most you will need 550, 440s might work? The maf your only going to need if your going to push 430+.
Old Jun 21, 2012 | 08:00 AM
  #106
ibelonginprison's Avatar
ibelonginprison
lawlz... Adrian is the fun police.
Old Jun 21, 2012 | 08:58 AM
  #107
Calinismo350z
thanks exemption. now ive heard theres some guys that had put up to 650cc on with the Ss box and work perfect.do you thing is gonna be an issue if I put the 550cc?? and if I put them can I drive it like that about an hour away? the reason it's because the only shop that it's able to tune it it's an hour away from me.
Old Jun 21, 2012 | 10:23 AM
  #108
lillong1991
I put the 650cc injectors in mine in case i ever wanted more power. i Wouldn't have to swap the injectors again. I know some people make like 380-400whp on 440cc injectors. The injectors should be fine without a tune if installed correctly and you dont push the car hard at all for that hour drive.
As far as the UpRev GT MAF and the fuel return system, you dont need these but I got them in case i ever wanted more power. It would be less to worry about if i ever went down that path.
  #109
ibelonginprison
Just don't get into boost. Drive easy, easy, easy, don't get past half throttle, and you'll never even touch boost. Or, take the blower belt off and don't even worry with it.
Old Jun 21, 2012 | 10:42 AM
  #110
Calinismo350z
thanks for the input. hope I can install the injectors next week and take it to get tune I
pretty sure I'm honna be making around 400whp and around 360wtq or a little less. and About the injectors I think I'm honna go with 550's since I don't gonna put any more pressure on my stock block maybe later on if I deside I want more lower I'll go with the stroker 4.2l but for now I think 400whp is good enough to leave some people with their mouths open.. haha
Old Jun 21, 2012 | 10:56 AM
  #111
ibelonginprison
400whp is plenty quick enough. And 340-350tq is still beefy without being dangerous enough to bend rods.
Just be sure to use the lubricant that comes with the injectors when installing them. And if you got them used, then use a little vaseline on the o-rings when installing the injectors. Makes it go MUCH more smoothly, and you won't end up with a leak or torn o-ring.
Also be sure to check your plenum for leaks when you reassemble everything.
Good luck to you.
Old Jun 21, 2012 | 11:18 AM
  #112
Calinismo350z
Good luck to you.
alright Vaseline has been add it to my buy list. haha and I will double check for leaks. another thing have you ever heard about any issues of cluth getting stuck half ways? I haven't done mods to it still stock clutch.
Old Jun 21, 2012 | 11:28 AM
  #113
ibelonginprison
You talking about the clutch pedal getting stuck halfways up? Is there a lot of loose, unusable, play at the top part of where the pedal sits? Or does everything feel normal, and it just "sticks" halfway up when you release it?
Old Jun 21, 2012 | 11:37 AM
  #114
Calinismo350z
it prob gets stuck about 70% when I realease it. and yeah I'll say it has around 10% or more of loose. and if I drive it normal it wot get stuck only when I launch hard but after driving it for a while it goes back to normal.
Old Jun 21, 2012 | 01:47 PM
  #115
ibelonginprison
bleed the clutch system like a stuck pig and see if that helps.
Old Jun 21, 2012 | 02:38 PM
  #116
Calinismo350z
where does it has the bleeding screw? and hat are the steps to do it? is it same as the brake system push it a couple of times then open the bleeder.?
Old Jun 21, 2012 | 07:40 PM
  #117
lillong1991
I already want more power. haha
Old Jun 21, 2012 | 09:13 PM
  #118
Calinismo350z
yeah I get you, boost is a little addicted ... haha I think my next step would be build engine with TT but that would be in a couple a years more. too much $$$ . and about the cluth fluid bleeding I got it alreay from YouTube.
Old Jun 21, 2012 | 09:43 PM
  #119
lillong1991
Haha already thinking about your next setup. I love it. I already know mine too. haha LSx swap...
Old Jun 22, 2012 | 06:01 AM
  #120
ibelonginprison
Oh, no doubt. We ALL want more power. haha
What I'm saying is, 400whp is no slouch.
