Water temp sensor location
Old May 10, 2012 | 04:46 PM
=Cerberus='s Avatar
=Cerberus=
Default Water temp sensor location
For those of you who have installed your own gauges, or at least know where everything is, where have you put the water temp sensor?
The first thought that came to my head is one of the main coolant lines, but since it is controlled with a thermostat I wasn't sure if that is the best place. I am also trying to not dump all the coolant if I can help it.
Old May 10, 2012 | 06:42 PM
thespottedcow's Avatar
thespottedcow
I remembering seeing some site selling one that goes in the upper radiator house somewhere. I know you had to cut the hose, Im guessing it would go up against the radiator, but Im not sure. Hope that helps.
Old May 10, 2012 | 06:45 PM
thespottedcow
http://www.z1auto.com/prodmore.asp?m...ne&prodid=3515
Thats what I was thinking off, just google, water temperature sensor adapter
Old May 10, 2012 | 07:26 PM
=Cerberus='s Avatar
=Cerberus=
Yep, I completely forgot about those. That's the answer.
Old May 11, 2012 | 04:30 AM
Rob@Z1's Avatar
Rob@Z1
I threaded mine into the rear coolant pipe, the connecting pipe between the heads by pulling out the old barb for the Throttle body lines and threading that hole.
But for the easier route, we also offer one a little cheaper http://www.z1motorsports.com/upi/pro...oducts_id=2822
Old May 11, 2012 | 06:07 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
We drill and tap the aluminum upper radiator pipe that comes off the back of the heads and around the passenger side of the motor
350z82
Oct 1, 2015 06:25 PM
Tochigi_236
Sep 27, 2015 03:40 PM
SharX59
Sep 27, 2015 09:23 AM
