Questions + issues w/ the Fcon and cruise/idle. Plugs keep fouling??
Old Apr 18, 2012 | 10:08 PM
Everybodywildou's Avatar
Everybodywildou
Default Questions + issues w/ the Fcon and cruise/idle. Plugs keep fouling??
I have a Fcon w/ 1000cc injectors and was wondering a couple of things.
1. What controls the cruising A/F as well the idle A/F? Does the Fcon control it or the Stock ECU? It seems to run rich during both. In the mid to high twelves during both. WOT seems good though.
2. What controls the start up? Does the stock ecu control this? The car doesn't seem to be taking to well to hot starts. Sometimes it won't start when hot. If I leave it for a couple of hours it starts up. Seems like it soaks the plugs in the fuel causing it to not start or something.
3. Could cruising rich like that be the reason the plugs are fouling and possibly causing the issue with the hot starts? Seems like when I change the plugs the hot start issue isn't as great.
So w/ all this being said, what needs to be adjusted? Should all the adjustment be done on the Fcon and not on the ECU? Fuel enrichment during start up need to be taken back?
Old Apr 19, 2012 | 09:59 AM
str8dum1's Avatar
str8dum1
its all done with the fcon.
If your car already is too rich at cranking, it will be even worse under a hot start.
the cranking and fueling tables need to be adjusted.
Old Apr 19, 2012 | 08:04 PM
Everybodywildou
Yeah I'm just wondering why my plugs keep getting fouled over short periods of time.
If the plugs are starting to get fouled would this cause the A/F ratio to be in a richer condition?
Old Apr 20, 2012 | 05:50 AM
str8dum1's Avatar
str8dum1
maybe, but by then your car would be running like crap.
Your tune is WAY off if you foul plugs that quick
Old Apr 20, 2012 | 06:09 AM
djamps's Avatar
djamps
If the car were mine I wouldn't drive it until the tuning issue is sorted. You have extreme wear on cylinder walls and rings because excessive fuel washes away the oil. You probably have alot of fuel in the oil as well.
Unfortunately, not many tuners can deal with FCON since it is locked and required the tuner to have a key. To make matters worse, HKS dropped all support in the US so it's basically an expensive brick at this point.
I would suggest if you have the funds to get a Haltech, or if you're on a tight budget go with something more basic like Uprev Osiris. With either, make sure your tuner knows what he's doing and sets you straight.
Old Apr 20, 2012 | 06:22 AM
graffkid732's Avatar
graffkid732
Wasn't the car running good for awhile though? Or has it always been like this?
Old Apr 20, 2012 | 09:31 AM
Everybodywildou
It was running well but it's been acting up I guess you could say.
Old Apr 20, 2012 | 10:46 AM
djamps's Avatar
djamps
Where was it tuned originally?
Old Apr 20, 2012 | 10:12 PM
Everybodywildou
GTM. Will whatever tuner I take it to know what parameters to adjust for cruising and idle?
Old Apr 21, 2012 | 06:45 AM
OMERTAITALIA's Avatar
OMERTAITALIA
the car was tuned at gtm in rancho cucamonga ca?
Old Apr 21, 2012 | 07:02 AM
str8dum1's Avatar
str8dum1
since they have to be HKS protuners, they will certainly know what to do
Old Apr 28, 2012 | 03:34 PM
Everybodywildou
Thanks man. Hey would you know if I could use my AEM UEGO wideband output to send the signal to my Fcon? Perhaps I could run a closed loop.
Old Apr 28, 2012 | 04:43 PM
djamps's Avatar
djamps
You need the AFK for that.
Old May 11, 2012 | 12:53 PM
Everybodywildou
Are you about that man? I was under the impression that the Fcon had a signal input for widebands.
Old May 11, 2012 | 01:46 PM
meatbag's Avatar
meatbag
You can run any 0-5v wideband output to the Fcon and use it for AFR feedback but you have to have the software to set it up in the Fcon.
Workshop12
Mar 23, 2020 01:45 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
350z82
Oct 1, 2015 06:25 PM
