Vortech CAI - will effect the tune?
Old May 30, 2012 | 06:07 AM
Sam Mcgoo's Avatar
Sam Mcgoo
Default Vortech CAI - will effect the tune?
Hi guys,
I've got some tubing, couplers and a new filter to make a CAI for my Vortech.
Will this effect my tune at all? (Uprev)
I assumed since Uprev uses MAF inputs that if there was any pre-maf flow change the fueling would be altered accordingly, but a couple of people have advised me to get it re-tuned.
Thanks in advance for your help.
Old May 30, 2012 | 06:14 AM
djamps's Avatar
djamps
As long as the MAF tube is exactly the same diameter as before you should be fine.
Old May 30, 2012 | 06:21 AM
Sam Mcgoo's Avatar
Sam Mcgoo
Not touching the maf tube, just adding 3.5" piping to the vortech intake to get the filter behind the bumper.
Old May 30, 2012 | 06:52 AM
TopgunZ's Avatar
TopgunZ
You are probably adding only a foot of piping to it. I dont think this is an issue. If you have a wideband just make sure its spot on after the install. But if your concerned about keeping inlet temps down for a lot less than a tune you could just add a vent if you could do it yourself.
Old May 30, 2012 | 07:02 AM
Sam Mcgoo's Avatar
Sam Mcgoo
Thanks for the replies.
I can't decide if I want to cut a hole in the bumper for the vent yet as I love the the smooth lines of the OEM front, although it give a more aggressive look.
This is why of gone the CAI route for now. I did get the K&N RX-4140 filter in case I decide to fit the vent at a later date.
Do you think the vent would give better results then?
Old May 30, 2012 | 07:05 AM
binder's Avatar
binder
it won't affect the tune.
It will draw in cooler pre-charger air which might help a small amount in intake temps but it won't change flow. Intake temps are compensated for by the ecu so the iats might stay a little lower and as you get on it the car won't pull as much timing.
being that it's pre-charger air it will be a minimal effect since most of the cooling is done at the intercooler anyways.
Old May 30, 2012 | 07:08 AM
Sam Mcgoo's Avatar
Sam Mcgoo
Cheers guys, I think I'll go and have a go at fitting it now. Its a lovely evening here.
Old Jun 1, 2012 | 01:49 PM
Sam Mcgoo's Avatar
Sam Mcgoo
All done, Cheers.
Old Jun 2, 2012 | 09:06 PM
binder's Avatar
binder
looks good.
I would try to adjust the angle so it's not behind the crash bar. That will help it get more direct air. Otherwise the air has to go under and around the crash bar to meet the filter.
Old Jun 5, 2012 | 11:39 AM
SexyRob's Avatar
SexyRob
well I can think of one thing that will affect it.. with mine, the stock filter was so bad that when I added my CAI onto the vortech I gained 1.5 psi of boost.
Old Jun 26, 2012 | 04:40 AM
wizard's Avatar
wizard
Is there any benefit in doing this?
I need a replacement air filter....
Old Jun 26, 2012 | 06:52 AM
binder's Avatar
binder
this is strange since a freer flowing system will have less backpressure therefore less "boost" (boost is only a measure of backpressure in the charge pipes).
in theory it will bring in colder pre-charger air. Any testing people have done shows that it doesn't affect power at all but I could see this a benefit maybe if you track the car since the heat in the engine bay would continue to build up and eventually cause the pre-turbo air to become very warm.
So basically if you tune it with good flowing air it will keep your car more consistent tune as you drive the car hard for long periods of time instead of slowly raising the intake temps over time. This also depends on how efficient your intercooler is since that's where the compressed air dissipates all of it's heat.
Old Jul 3, 2012 | 07:51 PM
SexyRob's Avatar
SexyRob
I think because my stock filter was crushed and a bit dirty / old it was just restricting that much air..
Old Jul 3, 2012 | 09:03 PM
binder's Avatar
binder
clean your dang filter ya hobo!
Old Jul 4, 2012 | 05:00 AM
SexyRob's Avatar
SexyRob
fyi
Old Jul 4, 2012 | 10:41 AM
binder's Avatar
binder
hahahahah, that is one sad looking stock vortech filter on the ground.
Old Jul 4, 2012 | 02:53 PM
Ruthless18x's Avatar
Ruthless18x
What was the length on that tube rob?
Old Jul 5, 2012 | 05:44 PM
fiteallison's Avatar
fiteallison
Old Jul 5, 2012 | 07:06 PM
SexyRob's Avatar
SexyRob
http://www.ebay.com/itm/4-OD-Aluminu...ht_3684wt_1163
2ndchanceZ
Oct 26, 2015 08:03 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
