Vortech COG Belt & Road Trips
on
I was wondering what you guys think about removing the cog belt before long trips.
I have searched and there are mixed opinions on that. Some say it removes the stress on the SC and engine, but some say that it can lean out or the oil flow into the v2 Vortech unit w.o the impeller spinning could be a bad idea.
The threads I've found were very old and had mixed opinions, so I was wondering if we could have an updated set of opinions on this.
I have been making round trips every other weekend with my Vortech'ed G (300 miles each way), and it would be quick and simple to remove the COG belt if it helps with the longevity of the system (and I guess save a few bucks on gas due to the parasitic loss)
Quick background, a few of my mods that might affect the decision: Uprev Tuned, Walbro 255, DW 600s & 19 Row Setrab Oil cooler. I also try not to hit boost after a while into the trip to keep the stress down, since the engine is running for so long.
Disclaimer: No, I don't wanna buy a beater and use it to make the trips
Thanks!
Thanks!
on
Thanks!
Thanks!
+1 on staying out of boost. I dont see how it could create a lean situation, however oil flow without the impeller spinning may create excessive blow by due to the oil not having its normal flow through the bearings...Im just throwing out possibilities, dont quote me! lol, this is a good question though...
Subscribed for curiousity
Typically when you remove the belt from what I've seen you're gonna be running rich not lean. Be easy on the gas or it'll bog out rich if you're too aggressive. Stock ECU uses pedal input just as much as MAF to predict fueling.
I've probably driven about a 1000 miles over the last 2 years with the cog belt off for problem elimination mostly, but never had any running problems and keeping an eye on my AFR it never seems far off.
My only thought is where is the Intake air coming from? Is it pulled though the non-rotating charger making it a difficult route for the air to take or is the BPV open and it draws though there?
I wasn't sure so fitted a filter to the BOV anyway.
I can't see the oil flow being a problem, surely it will still just flow through and back to sump.
That doesnt even make sense. The car will never leave vaccuum without the belt, ie never leave the low MAF fuel cells. If the car was gonna bog out, it would do it with or without the belt. It not like his tune is only setup for 600cc or whatever injectors only while in boost.
on
You will need a filter on the BPV because air will be pulled in through that passageway.
on
Doens't the tune modify the AF ratios at the higher RPM based on the fact that the high rpms will be seeing boost?
I assumed it would run lean w.o the cog belt due to that fact.
on
Maf tuning is based on air flow. As boost goes up air flow increases. If you never have boost then the air flow can only get to 0psi which is the same flow no matter what. Therefore the airflow reading (maf reading) won't go into any of the cells that are tuned for boost.
Plus the MAF tuned ECU has no idea of vacuum vs boost. Vacuum might take up 10-12 columns and boost is 1 or 2.... nothing like you're used to with MAP.
I'm not just making this up I'm going off experience (locals driving around with busted belts) as well as Osiris manual and input from Jared.
Long story short... Floor the gas in an Osiris tuned vortech with a busted belt and you will go rich.
The only thing that I can think of to explain it is the fact that throttle input is used in fuel calculations...NOT just MAF.
If you look at the fueling table you will see that the horizontal axis is fuel schedule... NOT MAF/MAP values like you're used to on your haltech/proefi.
According to Jared the primary inputs used to calculate fuel schedule (horizontal cursor position) is both throttle and MAF inputs. Thus, even in absense of full MAF voltage (no boost) with the pedal floored the ECU can still target areas which would have previously been considered 'boost' areas.
interesting...
How do you tune a turbo then when boost and rpm have no relation? I would think that issue would be a real problem, esp with a super fast or super slow lag turbo.
You romp on the gas, the turbo lags, and the car goes super rich (map goes into "boost" cells before the car is actually making boost), or romp on the gas, fast spool, car goes lean..
on
Thankfully it was just a few drops and it didn't hydrolock, otherwise I'd have been really pissed, and really embarrassed.
Having said that, I can't answer for any other "possible issues" with the Vortech because I don't have one.
on
In Osiris, MAF isn't the only input that decides BFS... throttle input is a huge part, probably even more than MAF.
ah, genius idea. simple clamp on the vac line.
