S&R single turbo kit
Old Jul 10, 2012 | 01:56 PM
FastWhiteZ's Avatar
FastWhiteZ
Default S&R single turbo kit
I've been a member here since 2007 and have learned an incredible amount from the community here. I started looking at getting the Greddy TT setup but thought that the price was a bit out of my reach at the time. A few years later I heard about the Momentum ST kit from the guys at S&R performance in Tampa, FL. These guys had a great facility and showed real knowledge of our platform. Soon after that I had them tune my car with Osiris netting me 264whp/245wtq. When I was finally ready to order the Momentum kit I was notified that they had gone out of business!! S&R asked me if I wanted to be part of the prototype process for their own ST kit and I jumped on it.
S&R single turbo kit-426961_2954672459689_1047753515_4696996_1692645948_n.jpg
S&R single turbo kit-420451_364285000261038_137837672905773_1218711_123162603_n.jpg
The kit came with:
Precision 62mm Turbocharger
Turbosmart compgate 40mm Waste Gate
Turbosmart Race Port Blow Off Valve
SS 3" Down Pipe w/ Flex Section
SS 2 1/4" Up Pipe & Gate Pipe
SS 2 1/4" Cross Over Pipe
S&R Oil Catch Can
S&R Reservoir Tank
3" Intercooler Piping
3" Intake
K&N Intake Filter
Bar and Plate Front Mount Intercooler Kit
Turbo Diaper
Vibrant 4 Ply Couplers
Vibrant SS T Bolt Clamps
Turbo Installation Hardware
Oil Sandwich Plate Adapter
Old Jul 10, 2012 | 02:04 PM
FastWhiteZ's Avatar
FastWhiteZ
These are the Dyno results:
S&R single turbo kit-430667_364284970261041_137837672905773_1218710_151699671_n.jpg
416whp/405wtq at 6.3psi
S&R single turbo kit-417160_364284903594381_137837672905773_1218707_391688020_n.jpg
Dump tube
S&R single turbo kit-420001_364284846927720_137837672905773_1218705_546085830_n.jpg
the way it looked on the day I got it back.
Engine today.
I've had the kit for almost 5,000 miles and haven't had a single issue. The guys at S&R did a great job and I couldn't be happier with my setup.
Old Jul 10, 2012 | 02:18 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Congrats. Which Precision 62mm turbo do you have? 6262 or 6266? Also what size turbine housing?
Old Jul 10, 2012 | 04:13 PM
FastWhiteZ's Avatar
FastWhiteZ
Thanks! I have a PTE 6262 with a V Band .82 AR housing.
Old Jul 10, 2012 | 04:22 PM
str8dum1's Avatar
str8dum1
I wonder if its just the smoothing they use on their graphs or the kit itself, but that boost curve is sooo lazy.
The fab work is very nice for sure!
Old Jul 10, 2012 | 04:27 PM
FastWhiteZ's Avatar
FastWhiteZ
I don't know man, on first an second gear it goes from 1psi to 6psi in an instant. This is a fourth gear pull so I don't know what would make the boost curve seem "lazy". It feels great on the street though!
Old Jul 10, 2012 | 05:03 PM
str8dum1's Avatar
str8dum1
its not hitting max boost til after 5500 rpms.
i guess with no boost controller and just on such a light spring, maybe thats just how those curves look.
6psi is barely even spinning that wheel. lol
Old Jul 10, 2012 | 05:16 PM
FastWhiteZ's Avatar
FastWhiteZ
I know!! that turbo isn't even waking up yet. I might get a boost controller an up the boost, but i don't know how much the engine can take? I got stock internals!
Old Jul 10, 2012 | 05:17 PM
FastWhiteZ's Avatar
FastWhiteZ
If I remember correctly I hit max boost at around 4700-4800rpm.
Old Jul 10, 2012 | 05:57 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
That's pretty laggy for a T3 .82 turbine housing. A GT35R is usually fully spooled by ~3500RPM. I would expect the same or better from a billet PTE 6262 CEA with a T3 housing.
Old Jul 10, 2012 | 06:16 PM
FastWhiteZ's Avatar
FastWhiteZ
I don't know what makes it laggy compared to the GT35R. Is there anything I can do about it?
Old Jul 10, 2012 | 07:26 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
The new 6262 CEA with a T3 .82 turbine housing should spool quicker than a 35R. I'd ask S & R for an explanation as to why it's not spooling up quicker.
Old Jul 10, 2012 | 08:42 PM
jerryd87's Avatar
jerryd87
for what boost your running that i absurd, i hit 20 psi by the same rpm your hiting 6.3 psi with a 6765 t4 .96 ar which is far bigger if your actually hitting that at 4700-4800. hell i think i hit that by 3k mayby slightly later, i am running 15 spring setup though.
Old Jul 11, 2012 | 03:14 AM
Exemption's Avatar
Exemption
could it be they smoothed it out for traction purposes? O.o..
Old Jul 11, 2012 | 08:01 AM
djamps's Avatar
djamps
A quality EBC should quicken the spool. Spring alone are always going to be a bit laggy.
Old Jul 11, 2012 | 11:45 AM
FastWhiteZ's Avatar
FastWhiteZ
This morning on my way to work I made a point to check when the car was making max boost. On first and second gear max 6psi came in an instant (~2500rpm). On 3rd - 5th, 6psi was reached at around 3500rpm. In one 4th gear pull it reached 6psi ~3000rpm. The car feels strong and pulls hard all the way to redline. I don't know why the boost curve shows 6psi at ~4700rpm on the dyno results.
Old Jul 11, 2012 | 12:16 PM
jerryd87's Avatar
jerryd87
lol thats alot better a ebc should indeed help that become even quicker if wanted though.
Old Jul 11, 2012 | 01:28 PM
FastWhiteZ's Avatar
FastWhiteZ
The plan is to get an EBC in the next month or two. I'm just wondering how much boost should i go with? or if I stay lets say at 6.5psi, how would it help to spool faster?
Old Jul 11, 2012 | 01:44 PM
djamps's Avatar
djamps
It holds the wastegate closed longer. The spring alone will open slowly as soon as you start building pressure.
Old Jul 11, 2012 | 04:52 PM
FastWhiteZ's Avatar
FastWhiteZ
Thanks for clearing that up for me!
