Bov vac/boost source?
Old Aug 3, 2012 | 11:21 AM
hulkout's Avatar
hulkout
Default Bov vac/boost source?
What is everyone using for a boost/vaccuum reference for their BOVs? My Tial says to use a 1/4" & that anything smaller will cause it to malfunction. do we have a secret 1/4" port I dont know about, or do I have to drill/tap my plenum?
Old Aug 3, 2012 | 11:33 AM
midz350's Avatar
midz350
which engine do you have? DE or HR?
Old Aug 3, 2012 | 11:39 AM
hulkout's Avatar
hulkout
Thanks for the reply. Its a DE. stock plenum.
Old Aug 3, 2012 | 12:02 PM
midz350's Avatar
midz350
There is a nipple in the front of the intake manifold.
The one where the hose connected to. No need for drill/tap your plenum.
Old Aug 3, 2012 | 01:38 PM
hulkout's Avatar
hulkout
Midz, I know about that one. Is that where everyone connects to for the bov? The Tial rep said to use a 1/4" ID direct line to the manifold. I have never heard of anyone tapping the plenum. But not many use Tials either. Maybe it needs more vac because its a pull type?
Old Aug 3, 2012 | 01:52 PM
midz350's Avatar
midz350
I used 2 Tial before. just use a direct line from anywhere in the manifold (after TB) to the BOV. Just use that nipple if there is nothing connected to it.
Also check the install manual for the GTM TT kit. They use Tial.
Old Aug 3, 2012 | 02:04 PM
hulkout's Avatar
hulkout
Oh ok good idea. I am using that port for the wastegates. I had been planning on using one of the ports on the aam throttle body spacer.
do you think that is ok? Or should I switch things up?
Thank you for sharing your experience.
Old Aug 3, 2012 | 04:49 PM
hulkout's Avatar
hulkout
Just in case someone is searching for this information later on:
The front vac port and aam tb spacer ports use a 7/32" hose. That translates to .21875". Obviously the 1/4" that Tial reccommends is .25. Only .038" difference.
Thanks again for the help midz.
Old Aug 4, 2012 | 10:03 AM
midz350's Avatar
midz350
Get one of these:
It will make your life much easier.
Old Aug 4, 2012 | 04:58 PM
binder's Avatar
binder
I use the front port but also have my plenum tapped for other sources.
The main thing with the BOV is to make sure you don't have the line t-ed with anything else. 1 connection to the plenum directly to the BOV. I always run a single vac line for every thing that needs it. No t-off sources.
Old Aug 4, 2012 | 05:27 PM
djamps's Avatar
djamps
I use the front port split for several things including the BOV. Something is tapped pre-TB but it's not the BOV.. I think it's the WG reference.
Old Aug 4, 2012 | 05:39 PM
binder's Avatar
binder
Hmm, I have seen a few instances of BOV flutter that were fixed by using an independent source for the BOV with nothing t'ed on it.
I'm sure the splitters might work on some vehicles but I always reduce the amount of things that complicate the system and could cause failure so I never use a common source for reference lines.
Old Aug 6, 2012 | 08:27 AM
psychoballistic's Avatar
psychoballistic
I have everything T'd together off that nipple on mine as well with the exception of one sensor.
Old Aug 24, 2012 | 11:44 AM
hulkout's Avatar
hulkout
Sorry for being so slow on my thank yous but thank you everyone. I don't have avacuum block, but im using the aam tb spacer and I hooked my bov to one of those. Fpr on the next one, and My map sensors to my gauge and utec t'd into the other.
Im using the front one for the wastegates. Just because thats what greddy told me to do.
Thanks again
lapham3
Oct 7, 2022 03:15 PM
