need some help with oil and water line feeders for gtm 350 turbo kit
Old Sep 17, 2012 | 09:01 PM
shane310's Avatar
shane310
Default need some help with oil and water line feeders for gtm 350 turbo kit
im installing my new twin hr trubo kit i got from gtm , and cant figure out where to get the oil and water feed from, i almost done with the kit but having hard time with this lil part ?
Old Sep 18, 2012 | 09:36 AM
GTM's Avatar
GTM
Vendor - Former Vendor
In the instruction manual on page 61, Step 8 (a) and (e), it tells you where to tap into the heater hoses for the water feed and returns. On page 64, there are some pictures of where to tap into the heater hose as well as how to route the line.
On page 61, Step 8 (f) it tells where to tap in for the oil feed. That particular step could probably use some clarification. There is a red oil distribution block (GTM-TTI-1) that has a 1/8" BSP female thread for the oil pressure sensor and three 1/8" NPT female threads. We supply two 1/8" NPT male to -3A/N male fittings and one 1/8"NPT male to 1/8" BSP fitting. The NPT to BSP fitting threads into where the oil pressure sensor was and into the distribution block. Install the two A/N to NPT fittings into the distribution block and each turbo oil feed line threads onto those fittings. The oil pressure sensor threads into the BSP part of the block.
If that doesn't help, give me a call or shoot me an e-mail.
(909) 481-4300
info@gtmpower.com
Thanks,
-Mike
apex locator
Jul 23, 2021 02:27 AM
