Help! Car won't start after turbo install.
Old Oct 20, 2012 | 02:16 PM
mknZ's Avatar
mknZ
Default Help! Car won't start after turbo install.
Hello fellow Z owners, so I got my turbo installed and tuned at sound performance in Chicago. So after I got home I was driving around town and I put the car in neutral to make a stop at a sign and the car died. I tried to start it and it cranks but doesn't turn on. I can't hear my fuel pump and also the windows don't go up in the on position. Any ideas? Any help is much appreciated
Old Oct 20, 2012 | 03:34 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Fuse maybe?
Old Oct 20, 2012 | 03:47 PM
mknZ's Avatar
mknZ
Yea it was a fuse. 10 amp! I checked about everything but that. Problem now is that it keeps blowing them. Tried a 15 amp and blew that too.
Old Oct 20, 2012 | 03:58 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
you have a short somewhere. Stop replacing fuses and fix the short.
Old Oct 20, 2012 | 04:40 PM
mknZ's Avatar
mknZ
Working on that right now. Thanks!
Old Oct 20, 2012 | 07:11 PM
ImWeeZzel's Avatar
ImWeeZzel
in for resolution
Old Oct 21, 2012 | 04:39 AM
deeno's Avatar
deeno
Which fuse blew?
Old Oct 21, 2012 | 05:09 AM
hellman_x's Avatar
hellman_x
Why not take it back to the shop?
Old Oct 21, 2012 | 06:35 AM
mknZ's Avatar
mknZ
IGN 10A ENG CONT INJ
I don't take it to the shop cause its 3 hours away. I gotta trace wires
Old Oct 21, 2012 | 06:39 AM
mknZ's Avatar
mknZ
I don't have a tester though so any ideas of what to check would be amazing.
Old Oct 21, 2012 | 08:28 AM
graffkid732's Avatar
graffkid732
Well what electronics did you get
Installed? Check where any wire could or would have been altered.
Old Oct 21, 2012 | 08:49 AM
mknZ's Avatar
mknZ
I got an Innovate air fuel gauge and a aem boost gauge. That's it. I'm gonna check connections to that.
Old Oct 21, 2012 | 09:42 AM
padilla03z's Avatar
padilla03z
they didnt install spark plugs too? they shoulda been under ur plenium working wit spark plugs and fuel injectors..look around those connections maybe? not an electronics guru..only other thing should b fuel pump but on another fuse. everything else should have been piping
Old Oct 21, 2012 | 10:56 AM
mknZ's Avatar
mknZ
I'm gonna wait and call sound performance tomorrow and see what's wired up to that circuit. The only things that don't work when that fuse is blown is the gauges (boost and afr) fuel pump and windows as far as I can tell.
Old Oct 21, 2012 | 11:13 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Fuel pump should be on its own 15 AMP fuse.
Should not be related to the windows.
Do not know why the guages would be tapped off the fuel pump power, i could understand the window motor power since that cable should be close to the A pillar.
Old Oct 21, 2012 | 12:53 PM
teamevolution2's Avatar
teamevolution2
stop replacing it with a larger fuse as well you will do more harm than good as it could cause the computer to get too hot.
Old Oct 21, 2012 | 02:56 PM
mknZ's Avatar
mknZ
Thanks I realized that, I only did that to get home. For a few blocks. My guess its the gauges but I can't do anything about it till tomorrow when I take it to a shop.
Old Oct 22, 2012 | 08:50 AM
mknZ's Avatar
mknZ
Called sound performance and they told me to check the connections to the gauges. Probably gonna take it to a local shop to check for connections and all tomorrow.
Old Oct 22, 2012 | 11:39 AM
bgant3's Avatar
bgant3
what he said....and if i were u, take it back to the shop that did the work. Dont want too many hands getting on it, then won't know who did what. good luck
Old Oct 22, 2012 | 06:53 PM
mknZ's Avatar
mknZ
That's what they said to bring it over, problem is they're 3 hours away plus I'd have to get a trailer and take a day off work. I wish I could but I just don't have the time. I'm just gonna have them look at the connections to the gauges and anything running from that fuse, hopefully it's nothing too complicated.
