Help with "clocking" compressor
Old Nov 10, 2012 | 12:15 PM
Zume's Avatar
Zume
Default Help with "clocking" compressor
I think this is called clocking... need to rotate the compressor slightly from its position where it is mounted to the turbine. How difficult is this "on car"?
I am fabricating custom tubing and am trying to eliminate this ~12° angle-
Here are two shots of a spare- Can I loosen the big bolts and simply rotate it?
THX
Old Nov 10, 2012 | 12:25 PM
Italianjoe1's Avatar
Italianjoe1
the correct way would be to loosen the snap ring and turn just the compressor housing, but due to access on the car, i'd say just do as you said and loosen the clamp bolts for the backhousing and rotate the center section with the front.
GurgenPB
Jul 30, 2004 07:23 AM
smcgee1970
Sep 4, 2003 04:15 AM
Rxramon
Sep 2, 2003 06:26 AM
