What gauges need for forced induction?
Old Jan 16, 2004 | 10:10 AM
jak's Avatar
jak
Originally posted by azrael
I'm building a custom setup myself, but if I were going with gauges, I'd get the Defi setup. It's by far the nicest one out there. HKS CAMP looks very "gimmicky" to me, but that's just my opinion. I'd really like to see it in person. The online pictures just look cheesy.
I will check out the Defi setup. Thanks for the info.
Jeff
Old Jan 16, 2004 | 10:16 AM
etx's Avatar
etx
I would go with EGT, boost, and a wideband for fine tuning. If your going to have it tuned by a pro you won't need to drop the ~$500 on a wideband setup.
Guru is a distributor for Defi, shoot him an email and see what he sells them for.
Old Jan 16, 2004 | 11:56 AM
12SecZ's Avatar
12SecZ
To answer the OP question.
I have Boost and EGT. By watching my EGT for months and knowing my A/F (you can get a dyno or other means) you can learn where your A/F is at and when you are on or off boost.
So how does this help you?
Well if I see my EGT is at 8 (going lean) then I need to pay close attention to my Boost Guage and try and keep it down
(your input in this scenario would be your feet to the pedal and clutch hehe) until you find out why you are lean (high Exhaust Temps) you can keep the boost off or low.
So my vote is EGT Boost which is what I have.
If you didn't have these? You wouldn't know you were lean, you wouldn't know what level of boost you were at.
I bought a new engine and wanted to break it in. I would have never known when I was making +1 or more boost w/o the guage right? You hear it kick in but do you know exactly how much you just made? No. What is iroinic is the boost guage is what I see most SCer uses here getting LAST!
Live and Learn as you can see you can spend 250 on guages or 2500.00 it's up to you, the important thing is to buy guages you can learn to use effectively which is what I did with my setup.
Old Jan 16, 2004 | 12:45 PM
jak's Avatar
jak
Great info! Thanks I will be definately be getting boost and EGT gauges.
My only concern is where to put them that will be both functional and reasonable looking. I saw a post where someone took the trip, oil, and volt gauges out and mounted different gauges in there place. That looked real good but I don't want to lose the tps or oil preasure gauges. My nav has an Alpine 760 monitor in it so of course I don't want to lose that. Where did you mount yours? Do you have any pics?
Jeff
Old Jan 16, 2004 | 12:56 PM
12SecZ's Avatar
12SecZ
Sounds like you are stuck with a pillar. I have a 7 inch flip up touch screen NAV/DVD/Camera,
I can't see my guages when it is up so it's either or.
Of course I don't race with the flap up so it works out for me.
When I am in the 11's with my A/F I have never went above 7 on my GReddy EGT even when on boost (7 lbs or under of course.)
Old Jan 16, 2004 | 12:58 PM
12SecZ's Avatar
12SecZ
screen down
GReddy AutoMeter
P.S. I wouldn't move my stock ones that is just me though, I would A Pillar the after maket ones!
Attached Thumbnails What gauges need for forced induction?-bestguages640.jpg
Old Jan 16, 2004 | 01:09 PM
jak's Avatar
jak
Nice install. I agree I don't want to mess with the stock gauges either. A pillar is an idea. Of course the HKS Camp system though azreal said the system was gimmicky looking and I have to admit the pictures on the HKS website do look rater cheesy. I guess I'd have to see it in person.
Jeff
Old Jan 16, 2004 | 01:16 PM
12SecZ's Avatar
12SecZ
Have a good car audio installer fabricate you a place, they put a center channel 4.5 inch Kenwood speaker in my dash and installed my guages, if you use electrical guages they should do a good job. After all it's just like building a kick panel when you think about it right?
The **** in the middle of my guages is the bass amp remote ****.
Audio Shop fab !!!
Old Jan 16, 2004 | 01:25 PM
narkotic's Avatar
narkotic
hey max whered you install the sensor for your EGT gauge? I hear cyl 6 is hard to get to...
Audio Shop fab !!!
Old Jan 16, 2004 | 01:30 PM
12SecZ's Avatar
12SecZ
passenger side post header but pre RT cat.
Seems to read well.
Old Jan 16, 2004 | 01:37 PM
12SecZ's Avatar
12SecZ
I'm an idiot, it's the driver side. Facing car top right is 6 right? Or is that 5? Either way they both blow first and that is the side mine is on.
thanks.
Old Jan 16, 2004 | 02:07 PM
narkotic's Avatar
narkotic
Sounds good... thanks!
thanks.
Old Jan 16, 2004 | 04:30 PM
350Now's Avatar
350Now
Originally posted by Z1 Performance
As with EGT probe placement, ideally you want 6 sensors...one in each runner. But its far from pracical. So what you do in that case is moniter your leanest running cylinder. So far, people seem to have blown cylinder 6, telling me it must run leaner than the rest (furthest away from fuel pressure regulator)...I would moniter than one, installing the probe in the manifold, -6 inches from the head. Obviously if your leanest cylinder is in check, your others are as well.
Thanks for the info. Very informative thread so far.
Old Jan 16, 2004 | 05:19 PM
12SecZ's Avatar
12SecZ
Do we have a FPR and where is it, next to the pump?
And cylinder 6 isn't farthest from the pump is it? It's closer.
You have me lost Adam, this is returnless and cylinder #6 is top right driver the pump is in the passenger compartment.
Think 350Z hehe focus lol!
Peas!
Thanks.
Old Jan 16, 2004 | 05:42 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
narkotic- we use Defi almost exclusively at the shop...awesome gauges overall, and loads of options for the money...they also offer some stuff noone else does, such as the LINK Display and the new Heads Up display.
If you need help with them or quotes, just let me know...happy to help.
I may be confusing myself...according to the manual, they make mention of a fuel pressure regulator....I have not gone looking for it yet.
As for the leanest cylinder, from the fuel rail diagram it would appear driver side, closest to the front of the car would be the leanest, as the fuel has the furthest to travel to reach that injector.....what cylinder is this (the one thing I could not find ANYWHERE in the book in the 10 minutes I looked )
Old Jan 16, 2004 | 06:17 PM
12SecZ's Avatar
12SecZ
That's 6 Adam but it's closer to the fuel pump than the forward ones because the pump is behind the passenger seat and there isn't a FPR next to it. The reason I jumped in is because I may be in the market for an FPR. Gotta quote
Make me an offer I can't refuse
Old Jan 16, 2004 | 06:25 PM
12SecZ's Avatar
12SecZ
I haven't checked the manual just looked under the seat and didn't see one (access panel) so if we have one then I would want to see if I can use it with a Walbro 155 and if not why?
I was told it isn't regulated in stock form but then again I was told the Aermotive is great too, I been told allot of thing ya follow me?
Let me know for sure
Peas!
Old Jan 16, 2004 | 06:48 PM
  #38
Z1 Performance
Former Sponsor
right...pum is behind pass seat..if you look at the rail desing, the fuel comes in on passenger side and there is a tube that connects the 2 rails along with a fuel dampener.
I would have posted the diamgram, but the site keeps editing it, so here is a crude drawing I scanned in at 8:00 AM this morning
Old Jan 17, 2004 | 03:19 AM
  #39
12SecZ's Avatar
12SecZ
Does the Crawford change that? Is there an FPR?
Thanks
Old Jan 17, 2004 | 04:33 AM
  #40
Z1 Performance
Former Sponsor
The Crawford plenum? No, there is no way to chage the stock fuel line layout, though there are ways to improve it.....how necessary that is, really depends on how far you intend to take the car I suppose.
As for the FPR, my manual makes mention of one though I cannot seem to find one....obviously there must be something in the system to keep pressure at a set level, though I have not been in my fuel pump area yet to know how the car does what it does.
