What gauges need for forced induction?
Old Jan 17, 2004 | 09:23 AM
  #41
12SecZ's Avatar
12SecZ
I meant does the Crawford change the fact that one cylinder seems to be leaner than others? A survey should be taken because it evens out the air I wonder if that changes the fuel areas? Just sorta talking out loud.
When you find the FPR let me know, I am being told I need one if I go larger on my fuel pump and was told I don't have one. My thoughts were if I did have one already I should be able to just drop that Walbro 155 in there and save 260 bucks shouldn't I?
I think the ECU is controlling the Fuel right now and the pulse and duration to the injectors , mine are 380cc's anyways we are off track and hijacked lol.
Old Jan 17, 2004 | 10:10 AM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Intersting idea...if anything it might exxgerae it more, if that cylider normally sees "less" airflow..having never seen the flybench rsults myself, I am not even sure how dramatic this is o the stock plenum to be honest. Then again, the ecu might compensate with the extra fuel....who knows
Old Jan 17, 2004 | 01:42 PM
  #43
FLY BY Z's Avatar
FLY BY Z
So the VQ cylinders are labeled opposite of the norm? I thought from looking at the car from the front the driver side left cylinder is #1 and works its way to the rear with the front passenger side is #2. Then back to the drivers side for 3 and so on. What is the firing order of the VQ?
Old Jan 17, 2004 | 02:28 PM
  #44
Z1 Performance
Former Sponsor
thats why I am unsure about honestly....I still have not seen a diagram labelling the cylinders or the firing order......I know which one is furthest (per my technical drawing above ), and I think 12sec said that was #6..I am honestly unsure
Adam
Old Jan 17, 2004 | 03:27 PM
  #45
FLY BY Z's Avatar
FLY BY Z
If it is anything like other V motors then the #6 is the cylinder closest to the passenger seat.
Old Jan 17, 2004 | 04:54 PM
  #46
12SecZ's Avatar
12SecZ
The order was posted in a thread here we could dig up, plus I have it on leak down tests.
It was that friggen 46 page thread though, I will find it because it was wrong the first time it was posted.
Old Jan 17, 2004 | 05:59 PM
  #47
12SecZ's Avatar
12SecZ
OK here is what my leakdown paper says
Driver Front 2
Driver Mid 4
Driver Rear 6
Pass Front 1
Pass Mid 3
Pass Rear 5
If I am wrong feel free to correct, I am curiuos too. Don't do the search it's a bad trip lol....
Old Jan 17, 2004 | 06:03 PM
  #48
FLY BY Z's Avatar
FLY BY Z
Yeah I was looking around searching for other stuff and came across that too. I have nothing to prove that it is the other way around. It is correct that the 1 and 2 cylinders are in the front but every motor I have seen have the 1 cylinder on the driver side.
Old Jan 17, 2004 | 11:45 PM
  #49
elektrik_juggernaut's Avatar
elektrik_juggernaut
Driver Front 2
Driver Mid 4
Driver Rear 6
Pass Front 1
Pass Mid 3
Pass Rear 5
thats what the Service Manual says too
Old Jan 18, 2004 | 01:44 AM
  #50
teh215's Avatar
teh215
Here it is from the Service Manual
Old Jan 18, 2004 | 03:40 AM
  #51
12SecZ's Avatar
12SecZ
cool,
Can you post a pic like that that shows the FPR setup?
Pretty neat! EJ came over and I am consistant 9-10 pounds now instead of 11, we dropped one tooth but more importantly my EGT temps dropped 200 degrees celsius so far. Belt is very tight.
I am leaning towards more fuel, need research on the FPR I know I am sold on that 155 drop in.
Thanks again bro.
Old Jan 18, 2004 | 04:05 AM
  #52
teh215's Avatar
teh215
The regulator is not adjustable if that is what you are looking for. I got an extra copy of the FSM from InsaneAmine when I got his grounding kit if anyone wants it I can send it for the cost of postage.
Old Jan 18, 2004 | 04:09 AM
  #53
teh215's Avatar
teh215
Fuel Regulator:
Attached Thumbnails What gauges need for forced induction?-fuelregulator.jpg
Old Jan 18, 2004 | 08:48 AM
  #54
Z1 Performance
Former Sponsor
see I just need to look more carefully Is anyone else finsing the OEM manual not as detailed as it is on some other cars?
Old Jan 18, 2004 | 05:11 PM
  #55
12SecZ's Avatar
12SecZ
So I guess you can't just drop a Walbro in there then. I hate Nissan , That isn't what I saw at RB but I was just looking at the stock pump out of the car, that looks like a one peice contraption assembly, after market would be two seperate units. Sigh.... More money....
Old Jan 18, 2004 | 08:15 PM
  #56
elektrik_juggernaut
i wish the frickin service manual would talk about the FPR in any kind of detail whatsoever!!!!
if we could see what was going on with it there might be a way to modify it for greater flow, since its non-adjustable
Old Jan 19, 2004 | 02:38 PM
  #57
teh215's Avatar
teh215
I have been looking at the FSM and it appears that the pump assembly must remain since it contains the fuel level sending unit. The up side is as far as I can tell is that the ECU only controls if the pump is either on or off. Unless I am over looking anything, any pump will work as long as you disable/reroute the OEM pump voltage and allow it to flow freely. Here is the electrical diagram:
Old Jan 19, 2004 | 04:31 PM
  #58
etx's Avatar
etx
Nevermind.
Old Jan 26, 2004 | 05:53 PM
  #59
Drag Limited's Avatar
Drag Limited
Originally posted by jak
Thanks for the replys.
Jeff
oil pressure, I lost my SR20 in 3 days due to low oil pressure and I had no clue. Spun a bearing
bcoffee20
Nov 19, 2015 06:39 PM
