Turbo VR6 in 350Z
Old Mar 11, 2013 | 04:16 PM
  #161
350VRz's Avatar
350VRz
My vintage aluminum bowl showed up today!! Perfect fit and about 3/32" thick, good enough to weld I just need to sand off the paint they used.
Old Mar 15, 2013 | 04:01 AM
  #162
350VRz's Avatar
350VRz
Here is the manifold cleaned up ready for the plenum. I should have the plenum on it by this weekend.
Old Mar 15, 2013 | 12:44 PM
  #163
Quamen's Avatar
Quamen
Nice! Nice to see more fab work on the forum!
Old Mar 15, 2013 | 12:54 PM
  #164
Spoolin'Fool's Avatar
Spoolin'Fool
youll never complete this! in for the final results, those VR6's sound mean as hell on boost haha, but why not R32 motor on boost if youre shooting for 600-700 i know they do that fairly regularly haha. but good luck sir, i like the idea!
Old Mar 15, 2013 | 05:07 PM
  #165
350VRz's Avatar
350VRz
The hard part is done, it's smooth sailing from here on out.
R32 motor is $2K for a used one and you still have to build it to make 800WHP. The 12V has way more aftermarcket support and a lot less expensive to work with. R32 is "better", but a Ford Pinto does 45mph the same as a Lambo does 45mph; One just cost much less to get to the result.
Old Mar 15, 2013 | 05:15 PM
  #166
Triji's Avatar
Triji
(lol) ... I am pretty sure a VR6 will get the job done! Check this ish out!
Good luck with the build op!
Old Mar 16, 2013 | 05:41 AM
  #167
350Zenophile's Avatar
350Zenophile
Seems like when you've got that much power and stock gearing you should just start in 2nd.
Old Mar 16, 2013 | 05:58 AM
  #168
Spoolin'Fool
Ahh touche sir touche
Old Mar 17, 2013 | 05:08 PM
  #169
350VRz's Avatar
350VRz
Here are a few more shots of the manifold going together. I still have a few more things to do but it's going to do the trick when it's done.
Old Mar 17, 2013 | 08:01 PM
  #170
freddys 350z's Avatar
freddys 350z
is it me or is part of your new manifold missing in that last pic?
Old Mar 18, 2013 | 08:22 AM
  #171
djamps's Avatar
djamps
^^ didn't fit so it had to get sectioned off? Looks like there might be enough room if the runners were L shaped and the manifold were closer to the engine?
EDIT could have also removed that 2nd firewall.
Old Mar 18, 2013 | 08:24 AM
  #172
djamps's Avatar
djamps
Or install a different final ratio like most big power guys do.
Old Mar 20, 2013 | 05:00 PM
  #173
350VRz's Avatar
350VRz
Sorry for the delay in response, I was on a business trip for work.
Yes, the manifold is tapered down in the back section on purpose; this helps even the flow between ports. It also helped the manifold fit. I also redirected the intake so it points right to the air intake opening in the front core support.
Great read here: http://josephrinek.com/intakemanifold.html
Old Mar 20, 2013 | 05:15 PM
  #174
350VRz's Avatar
350VRz
I may use an Automatic rear diff to help with that.
Old Mar 21, 2013 | 01:55 PM
  #175
Resmarted's Avatar
Resmarted
3.3fd+35 profile tires (assuming you're using 18" wheels) and sticky rubber and you'll probably be set
Old Mar 22, 2013 | 03:37 AM
  #176
Quamen's Avatar
Quamen
I'd go with something like a 305/40 or 305/45 even if going for big power.
Old Mar 22, 2013 | 11:09 AM
  #177
350VRz's Avatar
350VRz
I'm going to put as much rubber as I can, including sidewall.
Old Mar 22, 2013 | 12:35 PM
  #178
Quamen's Avatar
Quamen
Agree. Eltness350z is running 45 side walls which is a 29" tire.
Old Mar 22, 2013 | 01:18 PM
  #179
jerryd87's Avatar
jerryd87
just gotta be careful my 305/35/18's rub a little in hard turns im gona cut the quarters and widen em a little for now, looking at 325/40/18s but with my wheels that is likely gona rub both sides a little
Old Mar 23, 2013 | 01:12 PM
  #180
freddys 350z
do the same concepts of a n/a manifold apply to a pressurized turbo manifold?
