Seeking Knowledge on a ST build
Old Jan 18, 2013 | 11:14 AM
Eno's Avatar
Eno
Ah okay- I see what was being said and yes that makes sense... my bad.
Old Jan 20, 2013 | 07:00 AM
binder's Avatar
binder
Originally Posted by RudeG_v2.0
OK, now I understand what you are saying. Regardless, I think perceived issues or problems with heat soak get grossly overstated on the VQ platform versus other platforms that commonly run top mount turbo kits.
Well, I wasn't saying it was a problem but just pointing out the differences. With the gopro under my car on the dyno with 2 squirrel cage fans my hot side got to the point where it was glowing red on just single gear pulls. That's way too hot for me to want it 6" from my engine and hood. So a turbo blanket would be needed. Hell, my hood already gets hot enough to burn your hand if you touch it in the summer.
Originally Posted by warriors43
i know the z and g diffs are the same. but do i need to get the whole thing out of an lsd car. or just the guts and swap out.
Buy a whole diff and just swap them. Tearing the insides out isn't easy to do and you will need a shim kit to get proper alignment. Way more hassle than it's worth and used diffs aren't that expensive. $300ish
Old Jan 20, 2013 | 08:24 AM
herrschaft's Avatar
herrschaft
as far as the tranny im not too worried cause it wont constantly see the abuse. its a daily so it will likely normally be on a very low boost tune unless im going out to have fun.
At 460whp/wtq, my tranny lasted about 7-8 months before it started slipping. Expect to upgrade yours in the future.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
