RTWMOTOMomentum Single Turboo
Rod Knock is a horrifying and loud sound. Sounds like a Z I heard who's belt was partially torn actually. But the AFR thing is not good. I'll take another listen when my friends aren't making squawking noises. Could be piston slap... or maybe you detonated.
Pull the plugs, read them. Do a compression test.
http://www.angelfire.com/fl4/pontiac...Readplugs.html
and see thats where the confusion kicks in because its not really loud, not at all its just more of a tick
and the video isnt verry loud its probualy hard to hear i appologize recorded on the good ol IPHONE lol
Anyways so update i ordered me a short block this morning got lucky and found one already built so i dont have to wait the few weeks for it to be built
Still have yet to diagnose the problem but all in all this was a plan for the future so i just took advantage of it and did it early, so as we tear into it ill be sure to keep everyone updated
Stage 2 short block
Eagle Rods
Wiesco Pistons lowered compression 8:8:1
Acl Bearings
Arp Main studs
Hr Gaskets and Head Studs
Also considering a Cam since ill be down there anyways not sure what a good one would be
if anyone has any experience with different cams feel free to share id love to know
and or opinions on getting a cam or not
thanks everyone for your support and help
~Ryan
Stage 2 short block
Eagle Rods
Acl Bearings
Arp Main studs
~Ryan
Grats on getting a block ordered, hope it works out for you!
And I just listened to your video and that does not sound like a rod knock to me, that sounds nothing like the first video you posted of that other car w/ the obvious knock... That's more of a 'tick' than a knock... Not sure what it is but hell, a bit of duct tape, some gum and some spit woulda fixed that!
You need to check out what's actually the problem before you start throwing money at it.
Could be a 15 min fix.
Also I wouldn't just order a random built block, unless you know at least who the builder is, or the spec it was built to.
i thought it was injectors too especially since of my CrAzY a/f 's and hitting 10.0's on acceleration
another theory we are thinking is because of the amount i played with my boost controller i might have temporarily lifted my heads causing it to hydro lock and then after all the pressure re leaved itself i was able to start it again and perhaps a lifter was damaged in the process
but its hard to say untill we tear into it which we will do this weekened
as far as my block , block was built by Z1 and ordered from Z1 called to figure out how long it would take to build and they said they actually had built and could ship it whenever i was ready ( last friday )
Link to Block
the block then Arrived today at FedEx freight and and the ware house then called for confirmation to drop it off in the morning FedEx Freight
and yes i agree before throwing money at it it would be wise to check it out first but like i said earlier this was in my plans for the future anyway so i just took advantage of the situation and did it now
~Ryan
Link to Block
~Ryan
Update~!
Alright guys so all of us were taken by surprise on this ha is was exactly what i originally thought it was.
all valve train, injectors checked out good sent my heads off to the machine shop they said everything was good, they wanted to clean em up and then i can pick them up on monday
Dropped Pan Found this
All 6 bent and broke 2 squirters
shaved a little bit off
New block
New block
i have yet to figure that out either, she hates me just as much
and thanks hopefully in about a week maybe rolling over into 2 weeks all i have to do is put it back together now
and i boosted at 106k
Wow...those update pics should be a warning to all who want to boost especially at high miles...Glad you caught it in time before the unspeakable happens.
And +1 why does the GF hate us so? Either that or she just loves flippin the bird! Hahah!
Damn dude you destroyed that ishhh. Well now you got a built block thankfully. I just bought an aem boost controller for my 370 you should look into getting a EBC now lol. Ill keep up on your thread. Btw it's Jared
Bout time for an Update finally got it up and running again, wont tune and dyno untill monday
also added
open wastegate dump
1000cc injectors
for all the lovers
also added
open wastegate dump
1000cc injectors
for all the lovers
