New FI running, questions if "bugs".. or just "things to be expected"
Old Feb 19, 2013 | 06:21 AM
bmccann101's Avatar
bmccann101
Default New FI running, questions if "bugs".. or just "things to be expected"
Howdy.
Built engine
Osiris
PT6266 Vband .84ar
850 injectors
stage 0 CJM RFS
Mesh inlet screen only
Mishimoto Oil cooler kit
3" downpipe to single 3" main exhaust
reverse y pipe, running same duals out the back.
Tuned by Tony Lisa at UMS.
I have all graphs ( a/f, vac boost, hp tq etc) available in photobucket.
I am currently only running my MAP 2
AEM boost OFF/Wastegate spring 11 lbs street gas easy "safe" map. Around 475 whp.
My maps area as follows:
Map 1: pump gas high boost, AEM boost controller on/550 whp
Map 2: pump gas normal boost, AEM OFF/475ish whp
Map 3: pump gas HOT DAY map, more fuel, more timing/ whp unknown
Map 4: Q16 high boost map/ 650 whp
Map 5: Valet
A few things ive noticed I had questions about.
Upon normal driving around town, cruising at mid to low throttle, 45 mph etc.. i get an intermittent squeal/whine like a vacuum leak in a way, more like a squealer bar on a set of brakes.
Curious what that could be or if its common.
Secondly, flame all you want, this is NOT a race car.. its a cruiser..
the smell of pure gasoline is already unbearable. Its ok if IT smells like gas, but now I smell like gas too.. no good.
Test pipes were one thing when NA, but this car smells to high heaven. Like actual gas, not exhaust.
Wondering if anyone has gone w a bolt in 3" HFC, like a metal 200 cell etc... wondering what i can expect to happen w performance.. im ok w some loss btw. Id like to enjoy the car w the windows down.
Lastly, I did throw the SES light the third day of driving it.. p1273 and p1284.
Do you imagine i can use the bung spacers used in test pipes to spacer the sensor out a bit and help that issue or is it generally just the way it is?
Thanks for any input.. i hope i listed enuff here to let u know what my set up is.
Old Feb 19, 2013 | 11:01 AM
rcdash's Avatar
rcdash
Check by the manifold for fuel injector leaks (visualize around injectors and sniff). If that looks fine and AFRs are good, it's just routine rich exhaust smell. Have a 200 cell metal (or even 300 cell) metal cat fabricated and run that routinely. When you want to race, swap it out (v-band connections will make it easy). I run dual electric cut outs pre-cat (and have a 200 cell and 100 cell in series welded into each 3" pipe; needed because cats are less effective farther back - need heat).
Not sure about the squeal?
Old Feb 19, 2013 | 11:06 AM
bmccann101's Avatar
bmccann101
Ordered metal spun 200 cat..its a single 3" pipe
.I have a cut out just before where the cat will be
I'll check for injector leaks today
Thx man.
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
z33z_nutz
Sep 23, 2015 07:22 PM
Ace2347
Sep 22, 2015 03:12 AM
