Vortech motor build
Old 03-17-2014, 11:22 AM
  #101
the3kgt2
the3kgt2's Avatar
New pistons came in a while ago. Waiting for Rebello to put everything back together.
Old 03-21-2014, 08:36 AM
  #102
the3kgt2
the3kgt2's Avatar
The new motor arrived at ZCG yesterday. Now we wait for ZCG to toss it in. He's also flow testing the new injectors as well.
Old 03-21-2014, 06:03 PM
  #103
meanz
meanz's Avatar
Nice, not much longer..im still waiting on my block to get back from dynosty...they must of went on vacation or something cause its taking me forever to get mine back..
Old 04-14-2014, 02:46 PM
  #104
the3kgt2
the3kgt2's Avatar
ZCG finally has time to install the motor. They started working on it today.
They are going to uninstall the pathfinder mod since there was some uncertainty with it and it may have been creating some hot spots. Better to remove the uncertainty and protect the huge investment.
Old 04-14-2014, 03:48 PM
  #105
350z006
350z006's Avatar
Interesting theory on the Pathfinder mod creating hot spots...what's the full story from ZCG on that? Really curious to the logic behind this....
Old 04-15-2014, 07:21 AM
  #106
the3kgt2
the3kgt2's Avatar
It's not so much a theory as it is a process of elimination. A lot of weird things were happening to my car that nobody had seen before on all the other builds coming out of ZCG and Rebello. It had horrible hot-start issues (both NA during the break-in and tuned with the blower), the water temps were fluctuating on the dyno, and lastly all 6 pistons eventually melted all on one side.
The Pathfinder mod is one of the few variables that has been different from their other builds. We're not saying it's to blame, but it's not worth the time and risk of leaving it on. I want to remove all doubt.
Old 04-15-2014, 07:42 AM
  #107
Patty
Patty's Avatar
why the pathfinder mod makes no sense on a build DE :
Originally Posted by Patty
if you have an built bottom end, there is no need for the pathfinder bypass. Piston clearance to cylinder bore with forged internals is enough. You should keep one thing in mind : the water you pass by at the end of the engine reduces the amount of water, what flows through the heads. Cylinderhead cooling in a DE is much worse than HRs have. Open bypass (pathfinder mod) limits waterflow and cause high potentially in-head overheating as well as stressing the head gaskets..
Old 04-25-2014, 07:37 AM
  #108
the3kgt2
the3kgt2's Avatar
Got the car back last night. It has about 130 miles on the motor and so far feels strong. This time I'm breaking it in with everything on (e.g. blower, 900cc injectors, etc). We're keeping it under 4k rpm and no more than 1 or 2 pounds of boost until I hit 900 miles...then I'll take it in for the final tune and post up some numbers. Can't wait to see what it can do.
Been toying with the idea of swapping the UpRev for the Haltech Plug'n'Play. Not only does it have more safety features, Dynosty said they gained 50hp just by swapping the tune to Haltech (seen here). If only it wasn't nearly $3k with all the bells and whistles. Might wait until next year for that.
Old 04-25-2014, 07:52 AM
  #109
JoshLarson
JoshLarson's Avatar
Good luck with it man! Sounds like its been rough so far, but hopefully the end result is worth it.
Old 04-25-2014, 09:01 AM
  #110
- bigc -
- bigc -'s Avatar
glad you've got your baby back
Old 04-25-2014, 10:45 AM
  #111
2004Black350z
Exhaust Whore
2004Black350z's Avatar
Awesome. Can't wait to see numbers and video of sound
Old 04-25-2014, 12:36 PM
  #112
meanz
meanz's Avatar
Congrats, wish dynosty would pick up the ball and finish my block...
Old 04-29-2014, 09:02 AM
  #113
the3kgt2
the3kgt2's Avatar
350 miles and the car is still driving well. No hot-start issues so far...it starts every time. I can only take it up to 4k rpm but it feels very strong. Every once in a while it gets a rough idle, and sometimes bucks a bit at slow parking speeds...but I'm confident it can be fixed when it goes in for more tuning time.
I had some time yesterday to swap in my new Depo 06+ headlights with STi-R lenses. Since I had to take off the bumper I thought I would snap some pics and share. Click on the images to enlarge:
Old 04-29-2014, 11:15 AM
  #114
Conway_160
Conway_160's Avatar
Man i cant wait till you can open this thing up all the way.
Old 04-29-2014, 02:48 PM
  #115
Staisman
Staisman's Avatar
Sun will burn spots on the plastic with clear lenses. I have this mod for a year now and plastic bubbling inside right under the lenses. Going to change back to original lenses.
Old 04-29-2014, 02:54 PM
  #116
the3kgt2
the3kgt2's Avatar
I don't think that's the sun causing the bubbling, it's the lenses...any lenses. The blacked-out Depo headlights are prone to bubbling in that exact spot no matter what lenses you use. Only fix is to repaint them. Depo only used a tiny coat of paint on these things.
Old 04-29-2014, 03:57 PM
  #117
Staisman
Staisman's Avatar
I have original Nissan lights that I painted black using High temp paint and ceramic primer. I repainted twice already and it keep bubbling. Also in DIY thread here people confirmed it. Clear lenses works like magnifying glass on the sun. With original lenses you won't have this issue.
Old 04-29-2014, 05:03 PM
  #118
the3kgt2
the3kgt2's Avatar
I think you're right. I just went out and took a look at them. There's already one tiny bubble in each headlight after just one day in the sun. Poop on a stick...everybody told me to get the STi-R lenses. Jerks, all of 'em.
Oh well, function over form I guess. At least they perform better at night.
Old 05-01-2014, 12:45 PM
  #119
Staisman
Staisman's Avatar
I hate to remove them too, but my bubbles getting bigger. Also its not just a paint bubbling there are holes in the plastic after I pilled the paint.
Old 05-14-2014, 06:35 AM
  #120
the3kgt2
the3kgt2's Avatar
Dropped the car off this morning for the final tune. It's going to be 100F today so we'll get the results in a few days or so.
Quick Reply: Vortech motor build
