New Stillen SC Kit on my HR:
Old Apr 13, 2013 | 12:53 PM
BigBlue's Avatar
BigBlue
Default New Stillen SC Kit on my HR:
Something new under the hood!
Old Apr 13, 2013 | 01:02 PM
tw2's Avatar
tw2
Very nice, how does it perform?
Old Apr 13, 2013 | 01:04 PM
Ruthless18x's Avatar
Ruthless18x
Numbers?
Old Apr 13, 2013 | 01:22 PM
midz350's Avatar
midz350
San Marino Blue
Old Apr 13, 2013 | 01:25 PM
WTFMike's Avatar
WTFMike
Numbers?
This.
Old Apr 13, 2013 | 01:46 PM
RUNWDVL's Avatar
RUNWDVL
Very nice. And keeping with the post.... numbers?
Old Apr 13, 2013 | 02:06 PM
Bmurray350z's Avatar
Bmurray350z
very nice.. +1 on numbers
Old Apr 13, 2013 | 03:13 PM
BigBlue's Avatar
BigBlue
Thanks guys, I'm kind of new to my town and I need to find out if any dyno shop/s around, otherwise I'm 100 miles from Vegas and I'm sure that there are plenty there. I am "very" impressed with this kit! My mechanic said that everything fit together perfectly (he races a lot and is impressed with the kit), but one hassle that you don't find out until later is that there has to be 4 little cuts out of some of the under structure of the hood for clearance. My car was pretty quick with my bolt ons, but in the 20+ hours that I've had this set up I haven't stopped grinning haha! Strong from the start up to the tripple digits; I need to get used to the higher speeds in shorter distances as you FI guys know and found out when you first went to FI. I would definitely recommend this new Stillen kit that uses the Vortech V-3. I will get #'s posted when I can; vid soon.
Old Apr 14, 2013 | 10:53 PM
drvqz33's Avatar
drvqz33
Nice pics! Numbers asap.
Some in cabin videos would be nice too
Old Apr 14, 2013 | 11:00 PM
taryon's Avatar
taryon
very nice!!
Old Apr 14, 2013 | 11:27 PM
meanz's Avatar
meanz
Car looks great, in for numbers!
Old Apr 19, 2013 | 09:47 PM
BigBlue's Avatar
BigBlue
I've been calling around and may not be a dyno anywhere close, but I'll stay on it! This kit is very impressive and on my way to Vegas Wed. I had a chance to test it out for the first time on the open road; I easily passed my fastest ever and at 157 was still pulling nicely; that was enough for me on that day, but in a few seconds would have easily been mid 160's! It is impressive with so little effort and not even trying was doing little bursts like from 80-130 quickly, etc.
Old Apr 19, 2013 | 10:36 PM
ADMAN's Avatar
ADMAN
Plenty of shops here in Vegas.
Old Apr 20, 2013 | 07:32 AM
BigBlue's Avatar
BigBlue
That may be where I will have to go for any dyno. Are there some that you know of that you would recommend in LV?
Old Apr 20, 2013 | 12:26 PM
ADMAN's Avatar
ADMAN
Doug's Dyno Power
http://www.ddynopower.com/
Lots of other places too. Most of the car clubs and track guys just wait for a "Dyno Day" somewhere in town.
Old Apr 20, 2013 | 01:14 PM
tcode's Avatar
tcode
No intercooler in this kit?
Old Apr 20, 2013 | 01:40 PM
86azms3's Avatar
86azms3
Looks well made...guess you have to stay relatively mild boost unless you go can pipe an intercooler....or there's always methanol.
Old Apr 20, 2013 | 02:48 PM
bigcloud's Avatar
bigcloud
There's an air to water intercooler in the intake manifold. Look at the two coolant hoses on the front of the intake manifold.
Old Apr 20, 2013 | 06:43 PM
BigBlue's Avatar
BigBlue
Yeah, there is a small intercooler in front of radiator, plus a heat exchanger inside of the manifold; all self contained. That little black box/container is coolant (seperate from engine coolant) that uses a small pump to circulate through the system. Compressor uses 4 oz. of a lube; drains out bottom of car through a tube plus there is a brass bolt dip stick on it also.
This shows the intercooler:
*I should be in the 7.5-8+ psi. This set up is very quiet compared to other SC kits I've heard; the "whine" of the blower. This one is smooth power, pretty stealthy. I still need to get the wideband + boost sensors and gauges installed.
Old Apr 21, 2013 | 01:11 AM
bmyles's Avatar
bmyles
As mentioned above, if you want to be technically correct, the heat exchanger is in front of your radiator, the intercooler is in the manifold
Anyways, centrifugal SCs don't whine. You're thinking of roots or twin screw type blowers. Centrifugal blowers, because of their similarities to turbos, should have a whistle/sucking noise. Surprised it's that quiet, actually.
