rcdash v3.0 (by Dynosty)
Old Jan 31, 2015 | 06:31 AM
  #141
str8dum1's Avatar
str8dum1
i'd put them right at the downpipe merge
Old Jan 31, 2015 | 06:57 AM
  #142
rcdash's Avatar
rcdash
I have spare bungs downstream, but not at the x-pipe if that's what you mean. I was just going to leverage one of the spares on either side - could test both sides but I figure it's the before/after that matters.
Old Jan 31, 2015 | 08:12 AM
  #143
trustr888's Avatar
trustr888
Looks good RC! Wasn't aware of this kind of configuration for the turbos.
Old Jan 31, 2015 | 10:08 AM
  #144
Conway_160's Avatar
Conway_160
I was just thinking damn those turbo's look low, but ill bet awesome spool time.
Old Jan 31, 2015 | 01:13 PM
  #145
Resmarted's Avatar
Resmarted
Lol low mounted turbos have been around since before 2010. Need to do more learning about these here turbo Z's. One well known example is the SP 350z. It's the best placement for twins
Rc for valve placement definitely go further downstream. Personally on your setup I'd put them right before the mufflers and simply drill a few holes in the valves to allow some exhaust through. Putting them further downstream will reduce the temp they see a bit and should help them survive.
Old Jan 31, 2015 | 02:14 PM
  #146
Conway_160's Avatar
Conway_160
I didn't know there was low mounted twins? I knew about mid mount singles but this build is awesome!
Old Feb 1, 2015 | 10:40 AM
  #147
juelz86z3303's Avatar
juelz86z3303
Lol
Old Feb 1, 2015 | 10:54 AM
  #148
Glex25's Avatar
Glex25
I believe SFR was one of the first TT kits for the G35 that hung them low and used a sump pump for the oil return and this was back in 2005
Old Feb 1, 2015 | 02:16 PM
  #149
str8dum1's Avatar
str8dum1
ya i had my SFR kit since like 2009. Raj took all the complaints I had on my kit and fixed them with his kit Now he's finally completing the copy-cat with the boost cut outs
LOL!
Old Feb 1, 2015 | 02:43 PM
  #150
trustr888's Avatar
trustr888
It's been a long time since I looked at the F/I thread for awhile. Was aware of most of them except this one.
Old Feb 2, 2015 | 02:00 AM
  #151
Resmarted's Avatar
Resmarted
LOL!
HAYUSH-TEG OG TURBO VQ35 LULZ
Old Feb 2, 2015 | 12:55 PM
  #152
rcdash's Avatar
rcdash
Drill holes in the valves to purposefully create an exhaust leak? Why? Is this to prevent excess pressure from bending the butterfly plates?
Old Feb 2, 2015 | 12:57 PM
  #153
rcdash's Avatar
rcdash
LOL!
I have the SFR turbo headers, but everything else is different I think. It was helpful cataloging all your complaints and sending them to Dynosty to ensure they addressed. ;p
Old Feb 2, 2015 | 01:11 PM
  #154
Resmarted's Avatar
Resmarted
Basically yes.
Think about it, even on a stock car, having completely shut valves would be problematic over time. I'm pretty sure you're not intending to have these on the mainline exhaust path, but rather as cutouts? But even then still would be worth it to have a few relief holes.
If you put a few holes in it would still cut down noise by a ton... It would relieve pressure and probably help with heat a bit.
I've yet to see an electric cut out that doesn't die, and most of the cars I know of that have them are basically stock cars with an exhaust. A lot of them even still have cats before the cut out.... Lol this tundra that I helped a guy rice out had his sh** out before 2 months... But it's your car! You do whatever you want. I would drill them with a few 1/4" or 1/2" holes, then sand and paint them with high temp paint on just the faces (not the edges of the butterfly).
Old Feb 2, 2015 | 01:55 PM
  #155
rcdash's Avatar
rcdash
^ the valves open at 2 psi, always, so they would never be under much load. Also there is always an exit path via the muffler. These are not in the main exhaust stream. They provide 2 more exhaust exits (muffler bypass) above 2-5 psi.
Old Feb 2, 2015 | 02:38 PM
  #156
Resmarted's Avatar
Resmarted
I can't imagine them causing a problem with your new exhaust if they're opening at 2psi. If you wanted to be really safe you could still drill them but realistically I don't think it would make much if any difference.
Old Feb 3, 2015 | 11:21 AM
  #157
str8dum1's Avatar
str8dum1
mine is at my downpipe X merge, prolly at the highest pressure point. no issues. mine dont open fully til 11psi.
Old Feb 6, 2015 | 05:24 AM
  #158
ttg35fort's Avatar
ttg35fort
Professional
Raj, do you know what spark plugs and gap you are using?
I was on the dyno yesterday and getting some missing above 5k rpm at high boost. I have 3 steps cooler spark plugs. My gap was set to 27 thousandths. We changed them to 20 thousandths and it still did it. We changed to coils with some used ones Roger had laying around, but it still did it. Next week we will put in new spark plugs and coils, and check all of the pigtails/connectors. I may need 4 steps cooler spark plugs, but not sure.
Old Feb 6, 2015 | 05:58 AM
  #159
rcdash's Avatar
rcdash
Not sure on gap but I use only 2 steps colder. Check supply voltage also.
Old Feb 6, 2015 | 08:40 AM
  #160
str8dum1's Avatar
str8dum1
dang and here I am on 1 step colder, or maybe even stock heat plugs with good timing bands...
3 step is way too cold. Your plugs are prolly fouled. 4 step would be insane. Unless you were running C16 all time, 1 step is all you need.
I'm gapped at like .027 i think
