My quest to 500whp (Vortech build)
Old May 14, 2013 | 09:06 PM
TSG-Z's Avatar
TSG-Z
Default My quest to 500whp (Vortech build)
My current setup is currently at 432whp, far below my goal of 500! I was informed by my the shop that I'm experiencing belt slippage around 10psi. I did some research and identified my build is missing a crank pulley. I'm currently looking at ATI or Fluidine, does anyone prefer one over the other, if so, why? Lastly, can you guys, whom I'm sure are much smarter than me take a look at my current mods and offer suggestions as to why I may be missing. Thanks in advance.
Carillo Rods
Arias Zero Silicon Extreme Duty 9:1 Pistons
ARP Bolts
ARP VQ35 Main Stud Kit
HKS Metal Head Gasket
JWT Valve Springs/ Retainers
NISMO Cams
Cosworth Plenum
Vortech Supercharger V2 SI
928 Motorsports Impeller
2.87 Pulley
2.62 Motorsports pulley (not installed)
GTM Pulley Tensioner
Spearco intercooler
TurboXS BPV
Walbro Fuel pump
Fuel Return line
RC 650cc Injectors
Haltech Platinum Pro Harness
DC Headers
Custom Test Pipes
Strab Oil Cooler
Nismo thermostat
HKS Titanium tipped, Hi-Power, True dual exhaust
ARC Radiator Plate
JWT Clutch/Flywheel
Old May 14, 2013 | 09:35 PM
OldManZ350's Avatar
OldManZ350
With a High HP Vortech Build, TimRod's Radius Rod Strut kit would be a great addition. Pushing the blower that hard will put much more load on the Vortech Bracket than it was Designed for. The Radius Rod will support the Bracket at the far end on the Blower side, stopping any bracket flex, that will contribute to belt Slip. The Radius Rod is a Must for high HP Builds.... Especially with the 2.62
Also looks like your Fuel System is Lacking if you would like to get the most out of your nice short Block and 928 blower. A Stage 2 CJM, Much Larger Injectors, Larger fuel pump (255 walbro will not cut it) maybe even a Twin 255.
How Big is your Intercooler? I'd look at some of the Treadstone ones, nicely made, good price. You need one that will a flow at least 1200cfm, a little bigger would be better.
Looks like it will be a nice build.
Old May 15, 2013 | 06:40 AM
meanz's Avatar
meanz
What are you revving to? Have a dyno?
Old May 15, 2013 | 09:31 AM
350z006's Avatar
350z006
For 500whp I suggest:
-tightening your belt even more (really, this can be done)
-928 Impeller upgrade (Or T-trim, whatever floats your boat)
-Timrod bracket stiffener
-Either Fluidampr or ATI will work (I've used both) but ATI may be a little better because bigger crank pulley = more belt wrap...just make sure you use an impeller calculator....you'll need to be around 60krpm to make ~500whp dynojet
Old May 17, 2013 | 06:01 AM
binder's Avatar
binder
I agree with this all. Your fuel system won't cut it. On a vortech system with that extra drag it usually loses a walbro 255 at mid 400hp (depending dyno and individual fuel pumps). You will probably need at least 800cc injectors as well with the larger supply line to flow better (stock supply line is tiny).
Adding the extra TIMROD pulley helps quite a bit on belt slip and tightening the belt like crazy as well.
I have an ATI super damper. Quite a few people use either of them and they are both good units. I see other platforms using the ATI more often and the fact that it was in stock when I went to upgrade swayed my decision.
Old May 17, 2013 | 03:27 PM
TSG-Z's Avatar
TSG-Z
Thanks gents @ ZDayZ right now, but I will post dyno graph as soon as I return home.
Old Jun 22, 2013 | 09:30 PM
TSG-Z's Avatar
TSG-Z
This is the dyno graph, sorry about the "huge sample" I cant get the shop to send me the dyno on electrons. Anyway, as you can see the belt slippage on there. Looking for advice, thanks in advance.
Old Jun 23, 2013 | 07:25 AM
bealljk's Avatar
bealljk
You didnt mention anything about an intercooler? But as mentioned above - look into the CJ motorsports stage 2 and bigger injectors.
I have the ATI dampener and I am with it, but I couldnt tell you which one is better.
Old Jun 23, 2013 | 08:39 AM
TSG-Z's Avatar
TSG-Z
Doing my initial searches, where can I find a CJM intercooler? Their website only carries fuel related products, aside from a full race manifold.
Old Jun 23, 2013 | 12:00 PM
OldManZ350's Avatar
OldManZ350
CJM make Fuel components.
Try TreadStone for Intercoolers
Old Jun 23, 2013 | 01:51 PM
Resmarted's Avatar
Resmarted
If you want a treadstone intercooler PM me, I have a really nice one that's completely brand new I could hook you up with for less than what treadstone asks lol.
Old Jun 23, 2013 | 05:30 PM
bealljk's Avatar
bealljk
yea, cjm doesnt make a intercooler that I know of…
check out their website -
http://shop.cj-motorsports.com/CJM-S...0zDEstage2.htm
I think you can buy from their site but check out Import Parts Pro dot com too…you may have to call (Kyle), but I ordered mine from him and was happy, I'm pretty sure he can offer you a better price. And if you need other stuff he can get it for you.
Old Sep 15, 2013 | 07:49 PM
TSG-Z's Avatar
TSG-Z
In the process of getting the radius rod strut kt, still on the lookout for a ATI crank. What's the largest IC I could use and keep the crash bar?
Old Sep 15, 2013 | 07:59 PM
Resmarted's Avatar
Resmarted
With minor modification to the bar I can fit a 4" core, the only limitation you'll have (if you're ok with having core behind the bar) is the width of the intercooler from end tank to end tank. Can't remember how wide mine is though.
Old Oct 21, 2013 | 08:51 AM
Max Streets's Avatar
Max Streets
You should defenitly be making 500hp with that setup fuel supply.
Old Mar 15, 2022 | 11:38 AM
kevbc's Avatar
kevbc
Default braket neded
Oldman350z where I can buy your braket for the vortech 350z DE ingine?
Old Mar 16, 2022 | 04:08 AM
jhc's Avatar
jhc
General & Tech Moderator
They're usually sold used as part of a kit. You can call Vortech at 805.247.0226.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
