FS: GTM HR Twin Turbo kit
Old May 26, 2013 | 03:55 PM
jason350z's Avatar
jason350z
Default GTM HR Twin Turbo kit
This is a GTM twin turbo kit for the VQHR 350z models 2007-2008
kit is used for about 5-8k miles. selling cause i dont have my z anymore.
kit includes all piping, clamps, silicon tubes, inter cooler with braket, 2 exhaust manifolds, 2 garret turbos, bolts nuts, all original metal gaskets, blow off valve, downpipes. the kit includes everything u see in the pictures.
starting price 5k plus shipping
u joint
Old May 26, 2013 | 08:56 PM
TeegsMR's Avatar
TeegsMR
Is this the tuner kit or the turn key? Any dyno sheets...etc? Pics installed?
Old May 26, 2013 | 09:37 PM
Marrocco350z's Avatar
Marrocco350z
Did you buy the kit new or used?
Old May 27, 2013 | 12:04 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Steal!!!!!!
Old May 27, 2013 | 04:30 AM
jason350z's Avatar
jason350z
Bought it new , it's the tuner kit. That's all the pictures I got
Old May 27, 2013 | 05:47 AM
bruthaboost's Avatar
bruthaboost
Thanks for offering at such a great price!
A few questions though:
I didn't see the "u joint" adapter in your pics. Is that included?
What does gtm do about the eval purge system? OEM is set up for NA, or vacuum only, adding boost is a significant change.
Also, what did you use for your turbo oil drain and where are you located?
Old May 27, 2013 | 06:06 AM
TeegsMR's Avatar
TeegsMR
So I need a fuel system and a tuner to make this work?
Old May 27, 2013 | 08:39 AM
jason350z's Avatar
jason350z
Yeah fuel system, tune, maybe oil cooler, clutch better brakes, exhaust and a proper and experience shop to install and tune. Specially to tune so ur car doesn't go boom
Old May 27, 2013 | 10:16 AM
bruthaboost
Originally Posted by jason350z
I didn't do the work on my z so not sure about the oil drain. But in my setup I had an oil pan spacer which had lines that feed and also drain turbos I also had a 34row oil cooler setup not sure how they routed it. as far as the u joint if u have any pictures of it I could look around my garage see if I left any parts out.
I'm located in ny, so it's too cheap maybe I should up the price ?
I'm at work so I can't access the pics I need to show you. It's the piece used on the steering shaft though. The kit can't be used without it.
Your price is reasonable. At the sums of money involved here there is buyer psychology that must be considered that doesn't exist at for pretty much any other car part: primarily this purchase represents a very large risk. The last turbo kit around this price level, a
greddy iirc, took a few months to find a buyer and he was offering a bit more value. Only the market and your patience will determine the "right" price point.
I was planning on going SC, but this has me reconsidering. Good luck with your sale!
Old May 27, 2013 | 10:20 AM
bruthaboost
Though not necessary, a boost controller would really let you get the most of your setup. Also some type of LSD if you don't have one already.
Old May 27, 2013 | 01:14 PM
jason350z's Avatar
jason350z
Never mind just found it will post pic tonight
Old May 27, 2013 | 01:42 PM
ImWeeZzel's Avatar
ImWeeZzel
How many miles are on this set up? Do you have better pictures of the compressor housing? Any cracks on the exhaust manifolds?
Its been awhile since I've seen an HR kit FS in the marketplace... Still need injectors+fuel pump to make this work. GLWS br0
Old May 27, 2013 | 03:20 PM
jason350z's Avatar
jason350z
no cracks on anything
Old May 28, 2013 | 06:09 AM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
This car was under water up to the windows during that Sandy storm. I would think these turbos etc would need rebuilding no?
Old May 28, 2013 | 06:56 AM
jason350z's Avatar
jason350z
Dude Wtf r u talking about!!!!
I encourage anyone to come see the kit in person there is nothing wrong with my kit .
Old May 28, 2013 | 06:58 AM
germanguy818's Avatar
germanguy818
PM'ed. Disregard that water damage comment
Old May 28, 2013 | 07:05 AM
jason350z's Avatar
jason350z
I encourage anyone to come see the kit In person, or ask me for pictures videos of what ever part of the kit u want, I will take pictures tonight I'm more detail showing the inside of the kit turbos, intercooler manifolds and pipes
Old May 28, 2013 | 07:51 AM
bruthaboost
You have PM
Old May 28, 2013 | 09:16 AM
jason350z's Avatar
jason350z
Pmd
Old May 28, 2013 | 02:29 PM
jason350z's Avatar
jason350z
clink on this link to see video of inside of turbos
http://s189.photobucket.com/user/jas...06731.mp4.html
