Built motor with stock ecu
I have a built motor with a stock Ecuador that I'm breaking in, currently at 1500miles however it threw a code for over-advanced cam position timing yesterday... Is this a sign that I need to install a stand alone ecu to better control my low compression 8.5:1 build. im running stock Injectors and ecu at the moment? Any recommendations for me??? I parked the car so there wouldn't be any further damage done.
Could be a sensor failing. I would check to see if the cam position is actually advancing like it should. If not it could be the actuator not working or the sensor just going bad.
