turbo v8 swap. 350z or g35?
Old Jun 16, 2013 | 07:29 AM
parish8's Avatar
parish8
Default turbo v8 swap. 350z or g35?
i am looking for any mechanical reason why one car might be better than the other for a swap. this will be a ls based motor with some boost and an auto trans. goals are close to stock looking, quiet, ~600+hp,
i like the exterior styling of the 350z better but everything else i am finding leans me toward the g35.
same price
g35 are mostly autos so i will get the right council and shifter.
g35's appear to all have leather and a nicer interior.
g35's have a higher(3.3) rear diff which is better for what i will be doing.
g35 has a small back seat which i like.
so what else is there that might make one car better than the other for a swap candidate? 350z is likely a little less weight.
also if anyone knows of any cars out there for cheap i wouldn't mind knowing about it. something with a blown motor would be nice.
edit: i just noticed the ls1 thread above. looks like i have a lot of reading to do. 53pages :-)
Old Jun 17, 2013 | 04:51 AM
Cass007's Avatar
Cass007
Originally Posted by parish8
i am looking for any mechanical reason why one car might be better than the other for a swap. this will be a ls based motor with some boost and an auto trans. goals are close to stock looking, quiet, ~600+hp, ... Not easy. You need to have good headers for this and that usually means big pipes and a deep rumble in the exhaust. You may be able to be stealthy around town, but that is a maybe. All car guys can tell my car doesn't sound right (like a V6) just by the tone at idle.
same price
g35's have a higher(3.3) rear diff which is better for what i will be doing. Non-factor, can find them fairly easily.
g35 has a small back seat which i like. This makes you whole decision.
also if anyone knows of any cars out there for cheap i wouldn't mind knowing about it. something with a blown motor would be nice. Search the marketplace, a couple of shells have turned up over the years. You can also look for people who went F/I and have blown their stock blocks and have no money for the rebuilds, they will sometimes let go of the whole car just so they have something they can drive again.
Old Jun 17, 2013 | 09:48 AM
binder's Avatar
binder
Only the auto trans g35 have 3.3. All 6mt have 3.5 rear end which is the same as the 350z (auto=3.3, manual=3.5)
I have a g35 and I love it. Mine is completely sleeper except black rims. Even down to stock exhaust with cutouts for my turbo when I want to use boost. It sounds bone stock until I open the cutouts and I'm pushing 650hp without a v8
Old Jun 17, 2013 | 01:14 PM
parish8's Avatar
parish8
thanks for the info.your saying the auto 350z is a 3.3 rear gear?
my real goal is over 1000rwhp but people dont take you seriously when you say that.
Old Jun 18, 2013 | 07:46 AM
binder's Avatar
binder
Yes, the auto transmission comes with the 3.3 no matter g35 or 350z. Plenty of auto guys that aren't boosted swap them for the manual transmission 3.5 to get a little more acceleration on their auto trans. The boosted 6mt guys generally swap to the 3.3 so either way you should be able to find someone to swap an entire rear end with you if you wanted to change.
Old Jun 18, 2013 | 06:22 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
same price
You can get 350Z's with leather interior. Look for Touring models.
The powertrains of the Z and G are identical except the driveshaft. Auto trans Z's come with a 3.3 diff like the G.
What auto trans are you planning to use for that power level?
Old Jun 19, 2013 | 04:48 PM
parish8's Avatar
parish8
4l80e. i expect to have to modify the tunnel.
a shift kit only 4l80e will hold a ton of power.
Old Jun 19, 2013 | 07:26 PM
herrschaft's Avatar
herrschaft
I don't know about the Z's, but the 06+ auto G35's equipped with the sports package came with the 3.5.
Old Jun 20, 2013 | 08:36 AM
binder's Avatar
binder
They must have changed it for the rev-up engines then. All auto transmission non-rev DE engine platforms had the 3.3 final drive. I was almost certain it was all the DE engines because I've seen a few members with rev up engines selling their 3.3 from their auto on the forums. Maybe they were confused on what they had.
Old Jun 20, 2013 | 08:41 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
This is the first time I've heard of this. The sport package includes the VLSD, but I've never heard of 5AT models coming with a 3.5 final drive. What/who is your source for that info?
Old Jun 20, 2013 | 08:44 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I don't believe so. I have an '06 G coupe w/ 5AT and sport package. All the auto trans G35's, including '06 models, have a non rev-up DE. Only the 6MT cars came with the rev-up motor.
Old Jun 20, 2013 | 08:48 AM
binder's Avatar
binder
I just looked in the service manual. It lists the 5at as 3.3 on all models up to 2005 (that's the newest version of the manual I have) and 6mt is a 3.5 final drive. All g35x are 3.3 as well.
It wouldn't make sense for them to change the final drive on an auto in 2006 only to change it again in 2007 to the 3.69 ratio that the HR engine uses. I don't have a manual up to 2006 to make certain though.
Old Jun 20, 2013 | 11:09 AM
ogiehooker's Avatar
ogiehooker
Default 2006 z 5 at
My Z is a 2006 5 AT..came with the 3.3 FD.
Old Jun 20, 2013 | 11:22 AM
meatbag's Avatar
meatbag
350z has slightly more room to work with under the hood, mainly in the radiator area
Old Jun 20, 2013 | 11:57 AM
herrschaft's Avatar
herrschaft
As far as a source goes, I haven't seen anything as of yet that states that. Even www.infinityhelp.com says all autos were 3.3. Bought my car stock from a dealership and it had a 3.5 VLSD, the same that came standard on the manuals. There's a few others on Driver that have noticed this as well.
Only the sedans had the HR motor and the coupes never came with a 3.7.
Old Jun 20, 2013 | 12:26 PM
Drako_MDx's Avatar
Drako_MDx
Post
About Final Drive on 06 G35... Check Attachment.
Attached Thumbnails turbo v8 swap. 350z or g35?-g35_2006_servicemanual_rfd-59.png
Old Jun 20, 2013 | 01:26 PM
parish8's Avatar
parish8
so not all rear ends are lsd? which models have lsd and which do not?
Old Jun 20, 2013 | 03:21 PM
binder's Avatar
binder
Interesting that they would change it right before a model change and only do it for a single year.
Old Jun 20, 2013 | 09:48 PM
- bigc -'s Avatar
- bigc -
well, the coupe didn't change in 07, just the sedan. so they got 2 years out of the rear end switch on the coupe which is all that matters (who really cares about sedans anyway? ).
Old Jun 21, 2013 | 09:03 PM
Jaxter's Avatar
Jaxter
Same Parish?
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
pdexta
Sep 14, 2015 11:27 AM
fst100
North East
Sep 8, 2015 11:37 AM
