I have a feeling it does work, The emanage can alter the ECU's injector signal from -80% to +100% Duty Cycle, or -20ms to +20ms Duration. So I think it should work, the s2000 guys run these injectors with the EU, shouldnt be much different. Hopefully it does work.
I mainly want to upgrade to new technology injectors. Currently have 600cc DW Denso. so looking into these which can flow near stock at idle and flow 1000cc, as added benefit it leaves me one less item needed to try e85
I had no problems with them, idled great and everything, but I'm running Osiris...now I'm running 2150cc injectors and still idles good with Osiris, but I did have to raise my idle a little...
I had no problems with them, idled great and everything, but I'm running Osiris...now I'm running 2150cc injectors and still idles good with Osiris,did have to raise my idle a little...
My ecu is not compatible with Osiris.
I have not found a thing that my EU cannot do, hopefully this will be a success. We'll find out in a couple of days.
I didn't know there were any 350z's that were incompatible with Osiris... Do you drive a 2003 G35 sedan?
Yet another reason why I think EU is as good as a stand alone (at least for MY application).
The car runs perfect, starts even better than before, and idle's at stoich even at open loop.
I also went for a drive and car runs great just need to do additional tuning. So in conclusion, EU + ID1000 works perfectly!
