Stillen Blower Questions
Old Jan 26, 2004 | 06:11 AM
LFR1Legend's Avatar
LFR1Legend
Question Stillen Blower Questions
Ok i wanna S/c the Z. I really like the stillen set up but,i have some questions
1. Ive heard some things about warranty....does it or doesnt it void the warranty on the drivetrain...I would think it does or stillen provides one.
2. Do you change injectors and fuel pump?
3. Do you change or reprogram your ECU.
4. How much is the whole ordeal gonna cost (like everything you bought)
Landon
Old Jan 26, 2004 | 07:00 AM
illegal imports's Avatar
illegal imports
The newly released STILLEN Stage 2 Intercooled Supercharger for the 350Z reaches another milestone. Already the first and only 350Z forced induction kit that can offer an extended engine warranty.
The Supercharger that is reliable enough to offer a 3yr/36,000 Engine Warranty
The standard kit has 5.7psi that kit is under warranty.
The one that is not warranted is the offroad kit that pushes 7psi.
The warranty cost around 300.00 .
The kit comes with a extra fuel injector.
You do not have to reprogram you ECU for this kit.
Old Jan 26, 2004 | 02:51 PM
m3powerrr's Avatar
m3powerrr
https://my350z.com/forum/showthread....threadid=58052
Currently it's boosting at 6.9psi.
Old Jan 27, 2004 | 07:24 PM
m3powerrr's Avatar
m3powerrr
hey if you are serious about wanting the stillen kit, let me know. I can get you hooked up on everything far less than retail which includes install. and we know pretty much everything about the install. on mine, we used it as trial and error and let me tell you, unless you are a good mechanic, then I advise you to let someone else install for you. for example, when you install the baffle, the spacers are not welded to the baffle and if one of those fell into the intake than you are in big trouble. here are some things to know. first check out my thread.
warranty is great if you want to stay with the standard kit. $260.00
do not need the intercooler at first but recomended later.
ground wire from the piggy back ecu must be grounded properly.
blower must be checked for bad gasket before installing.
make sure to follows the directions.
can ge the supercharger in 2 days. drive down to atlanta on saturday morning and drive home that same night.
but remember, who ever installs for you. make sure they are follow the dirctions.
and i have to say i am very happy with the reliability and gains I have gotten from stillen. well put together kit.
proof is in my dyno sheet. torque curve is the best part.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Alexreyes
Sep 30, 2015 11:30 PM
