Untuned ecu powerlab turbo question
Old Sep 29, 2013 | 06:01 PM
Z_on_TE37's's Avatar
Z_on_TE37's
Default Untuned ecu powerlab turbo question
This question is for the boost gurus out there. I'm in the process of installing my powerlab single turbo kit on my 03 350z and I do not have any type of ecu reflash or anything yet. I have my stock ecu and that's all. I will be getting it tuned on uprev as soon as I'm done installing it and can get it to the tuning shop. Will starting my car on the stock tuned ecu with the 600cc injectors and turbo kit hurt my car? I don't plan on ripping down the roads with it but can it be started and driven onto a trailer after the install on stock tune ? Thanks in advance
Old Sep 29, 2013 | 06:05 PM
tonyzS/C03's Avatar
tonyzS/C03
yeah you should be ok to put it on a trailer...
ksuberk54's Avatar
ksuberk54
I wouldn't install the injectors until you tune it
Old Sep 30, 2013 | 07:31 AM
evilscorp's Avatar
evilscorp
Drove my Vortech Z about 10miles and it drove like a pig with 600cc injectors ended up trailering it to the shop, yours will be worse but should be fine to get it on a trailer.Do u have a fuel return system? Also afr gauge would help, so you can adjust it so it runs a litttle better.
Old Sep 30, 2013 | 12:25 PM
Drako_MDx's Avatar
Drako_MDx
No problem at all if it's just to drive it up into a trailer.
Where do you plan on taking it to get tuned on Uprev?
