Perfect Power ECU
This unit is being installed on my car in conjunction with the ATI procharger,Aeromotive DFMU,and 8lb then 9lb pulleys....I am expecting to be @ 425whp with the 9lb pulley...Anyone interested in this unit PRE-Programmed to work in conjunction with a Tuned ATI with DFMU let me know.I am conducting a group buy on this item in the beginning of MARCH...This will come with the unit and wiring as well as tuning software giving the user full tuning capabilities over it...My current Group buy Price is $675 for under 10 units...If we go over 10 units-20 units I can do $600...Shipping will be flat rate of $15 within the US...
Please specify 8lb or 9lb program when ordering.This unit will also have 2 maps programmed into it,one for daily driving and one for max hp/racing...The maps can be controlled via a small switch mounted in the car..There is only one distributer in the us for this unit and he is the one I am working with and tuning the unit for me..Below is a link and a DYNO graph for my car tuned @7lbs with ONLY the DFMU no piggyback.Expect a DYNO for this unit by MID FEBruary....Also keep in mind this unit can control larger or secondary injectors to eliminate the DFMU...My car is being tuned with the DFMU and this unit to see the benifiets of adding this unit to an existing ATI procharger..The next step will consist of either adding seconadary fuel injectors or larger ones..I will keep you guys posted...
http://www.perfectpower.com/products/smt6.asp
PS MODERATORS can you please leave this under Forced induction as it applies to FI only...
Originally posted by zimbo
Sounds cool. What specifically does this piggyback chip allow you to control? I'm assuming it can retard timing and modulate A/F. What else?
--Steve
--Steve
The PBC (piggy back controller) versus the claimed ECU, should be a perfect match judging by the capabilities. I remember the smt6 now after looking at the web page. Best of luck man! I'm hoping the smt6 to work out like bread and butter so it can be a perfect solution as opposed to sending out the ECU to be reflashed
