Uprev tune single turbo
Old Oct 24, 2013 | 07:41 PM
Z_on_TE37's's Avatar
Z_on_TE37's
Default Uprev tune single turbo
I'm In the final stages of installing my powerlab turbo kit and I need to start worrying about tuning. I am going to go with uprev for my tuning software. Does anyone have any rough tune I can use to start with, I'm just learning tuning and I need something to get my car going so I can tweak the mapping. I'm running 6 psi with 660cc injectors. If anyone can help me out I would greatly appreciate it. Thanks for your time.
Old Oct 25, 2013 | 08:05 AM
str8dum1's Avatar
str8dum1
just use your base map. it will start and run with those injectors
Old Oct 25, 2013 | 12:57 PM
Z_on_TE37's
What are you referring to as base map, the stock tune or uprevs base map
Old Oct 26, 2013 | 02:07 PM
str8dum1's Avatar
str8dum1
whatever file you have from Uprev. You cant download anything off the stock ECU. So you have to have a stock map file from Uprev that matches your ECU code.
That file will start and run the car. Then you can start logging your AFR and make changes from there. There are so many ECU models, no one shares maps
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
