New (Sema Nov 2013) Vortech V2 Ti-Trim Blower
Old Dec 2, 2013 | 08:32 AM
OldManZ350's Avatar
OldManZ350
It's all good…… Just trying to get the Facts Out There!!!!!
I do not work for Vortech, but I did work for (back in the Day) B&M Automotive Racing Products, Mostly on their Roots Suercharger Line, Manual Shifter Line and Auto Shifter Line.
Old Dec 2, 2013 | 08:34 AM
Threads's Avatar
Originally Posted by Classy
I am not arguing with you... I swear you work for Vortech the way you are defending it...
The problem is, that it isn't that big of an upgrade for him. I am willing to bet he will make about 600hp at 55k RPM. Then what? He doesn't have enough displacement to make more power on it.
Remember he was spinning his to almost 70k RPM
Yeah, without knowing how many CFMs Colombo setup was actually producing, it's all speculation. I think we can all agree that the Ti would be more reliable than his previous setup.
If Colombo is looking for more room to grow, I would look more closely at the YSi. I believe that blower is rated at 1600CFMs. It's about $500-$600 more expensive and about a half-inch to an inch larger in most areas.
Also, a side note, just got word that my Ti supercharger will be arriving Wednesday.
Old Dec 2, 2013 | 09:18 AM
Classy's Avatar
Classy
Due to space problems already seen, I think a YSI may be a bit big for a 350Z.
My question is why are Prochargers not used on 350Z's? They are alot more expandable than Vortech it seems.
http://www.procharger.com/models.shtml
There is alot of expansion here and they run at higher RPM's too
Old Dec 2, 2013 | 10:09 AM
OldManZ350's Avatar
OldManZ350
The YSi Blower is a Great Choice….. especially for a Drag Car if you what 800whp+.
There is no"Space Problem"
All of this stuff is a Custom Installation.
Any Custom Install is going to require some minor modification for Proper Fit.
Procharger makes a top notch blower, but the kit they came out with for the Z and G35 in 2003 did not go over well, I think due to the complex bracketry and belt problems. They do not pursur this market any further, Vortech did.
Old Dec 2, 2013 | 10:13 AM
Threads's Avatar
I agree. Having used a YSi, it's tight, but it fits. From my understanding (so i may be wrong,) the gear cases are all the same size between the V1-V3 and V7 (possibly some others.) The only difference in size is with the volute. I only needed to remove some of the support on the driver's side to provide adequate clearance.
Old Dec 2, 2013 | 11:26 AM
Jaxter's Avatar
Jaxter
What is required to switch from a V-3 to a V-2? I would be willing to try this on my Stillen HR Kit. I guess just a pump and oil lines?
My V-3 SCi unit just got shipped in to Vortech for the Si upgrade last week. But that is only a 10-15% increase in CFM. The upgrade is cheap, but labor and a retune will add up. I'd rather swap to the V-2 Ti trim and slow the RPMs down to meet my power goals. Then I can swap pulleys and retune later on when my motor can support the extra HP.
Old Dec 2, 2013 | 11:32 AM
Threads's Avatar
All I needed was the oil supply and return for the blower (I went from a V3 to a V7.) I was able to get the drain and a spacer from a local, and I got my feed from superchargersonline.com
Old Dec 2, 2013 | 11:41 AM
Jaxter's Avatar
Jaxter
Thanks man. I'm going to bring it up to JTran tomorrow.
Old Dec 2, 2013 | 11:46 AM
Threads's Avatar
From my understanding, winksrt8 is overspinning the Ti to 64K. I'm really curious to know how much you can overspin the Ti "reliably." However, that might be an oxymoron…
You're welcome, and Good Luck.
Old Dec 2, 2013 | 06:05 PM
Colombo's Avatar
my goal was never initially to make 600hp. if this blower can make that within its 55k range then awesome. but it will atleast make 550 i would hope safely which will be more then enough for the road racing/autoX that i do....if a year or so down the line i want to see its limits "safely" i will push past that 55k mark. remember how much further i was pushing my blower w the 928m and it still took well over 200 HARD first- 3rd gear pulls and hard autox action before she threw the bearings. but before that i ran the stock sc impeller with the 2.87 to 7200 rpm for over 8 months autox monthly road course every other month with no issues at all. so imagine just slightly pushing that blower... but for now my main concern is decent power RELIABLY so i will not be pushing this blower for quite some time. hopefully within its 55k rpm i can make good power. i still am un sure which pulley i will run with my fluidampr to stay within the limits at 7500 rpm. but once i sell this momentum (potential buyer on the way now) i will order my TI :-)
Old Dec 2, 2013 | 07:17 PM
OldManZ350's Avatar
OldManZ350
I'd start with the 3.33 pulley and see how the dyne looks. Vortech also makes a 3.25.
Old Dec 3, 2013 | 07:29 AM
Colombo's Avatar
I have a 3.33 lying around somewhere. I know u hav told me before but what is the calculation that must be done to find ou how fast I will be spinning this thing?..
Btw my turbo kit sold yesterday and I ordered my Ti blower today, Vortech is going to buy back my blown blower Aswell so the damage wasn't bad at all. Just over 2k once all is said and done.
Old Dec 3, 2013 | 07:47 AM
Classy's Avatar
Classy
That worked out in your favor. I think it is a very good idea to calculate what you will be spinning the supercharger at with each pulley. I am interested to see what you 2 make on these blowers.
Old Dec 3, 2013 | 07:51 AM
the3kgt2's Avatar
the3kgt2
http://www.vortechsuperchargers.com/page.php?id=33511
Old Dec 3, 2013 | 07:52 AM
OldManZ350's Avatar
OldManZ350
That's great!!!!!!
Go to the IMPELLER SPEED CALCULATORS for V-2 / V-3 with Jack Shaft Calculator on the Vortech site.
Old Dec 3, 2013 | 08:20 AM
Colombo's Avatar
alright did the calculations for my setup with the 28/32 stock cogs fluidampr pulley 6.125 and the 3.33 and 3.12 this is at 7400 RPM which is what i was shifting at when it made 608 on the 928m impeller.
3.33 = 56155.56
3.12= 59935.26
from what vortech told me the only difference between the v1 Ti and V2 Ti is noise.
to my understanding the v2 TI it rated at 55k rpm... obviously although this is the HD gearset/bearings i do not plan on spinning this blower at 65k rpm like i did the 928m with std internals. but can it handle it :-X lol
threads, any idea which pulley you plan to try? i am planning on picking up a 3.12 and testing them both on the dyno i think. also what crank pulley are you on and what rpm do you plan to rev 2?
Old Dec 3, 2013 | 09:23 AM
Threads's Avatar
Colombo, I'm think I'm going to start with the 3.12 first (if it'll fit.) I have a 6.78" ATi crank pulley. I think I'm going to run a 32/32 setup to give me room to run my coated 2.87 pulley. I'll be shifting at the stock redline (6800.)
Old Dec 3, 2013 | 10:55 AM
  #38
Colombo's Avatar
Wow so u really plan on pushing this thing huh? U think this bearing set can handle that much rpm or will it fail like the std units did. I wish I was willin to push it but I cannot afford another 2k+ to find out this blowers limits haha
Old Dec 3, 2013 | 11:44 AM
  #39
Threads's Avatar
Like I said, I'll probably start with the 3.12. With my setup, and that pulley, I'm right at 55K @7000rpms. With the 2.87 it's 59K @7000rpms. Between belt slip, and only being at/around redline for a second or less, I don't see why overspinning it slightly (via the calculations) is a bad thing.
Old Dec 3, 2013 | 02:34 PM
  #40
Colombo's Avatar
No doubt man I guess I invisioned much higher numbers w the ati crank but te 32/32 prob helped a lot. Cannot wait to see your results post pictures when it gets to ya!!! I'm shipping my old 1 Tom to Vortech Jaimie told me around a week from when they get mine so I'll be a little behind ya!! Excited to see what these blowers do on the vq motor
