Setup for engine rebuild for fi 600
Old Feb 13, 2014 | 05:40 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
7K don't bother, but for 600 whp i will tell you what I was told. You'll regret not spending the money exactly 12 months later. The turbo you need to make 600whp will make 650 at lower boost with good cams. Give yourself a head start. Spend the money now instead of later and more. One labor bill is better than 2.
Old Feb 14, 2014 | 01:40 AM
aas350z's Avatar
aas350z
Ok last question do you see any sens to go with rev up cams insted of non rev up My friend sent me rev up intake cams and I can use them
Old Feb 14, 2014 | 05:34 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
That would be a bit out of my depth, I would call a shop to answer that question. I think it has more to do with proper cam phasing than anything, it may have a slightly higher lift and more duration but it may not ever time out correctly. I haven't heard of anyone running that setup, would be interested to know as well.
Old Aug 28, 2014 | 03:20 AM
aas350z's Avatar
aas350z
Short update the car is running at 20psi 650hp
Only one problem which I currently have is that boost starts from 3.5k rpm and full boost is on 4.5k rpm so late. Maybe due to the fact that I took rev up cams
Old Aug 28, 2014 | 07:43 AM
taywan's Avatar
taywan
Wow. Thats aweswome. What turbo kit are you running btw??
Old Aug 28, 2014 | 07:53 AM
aas350z's Avatar
aas350z
Greddy 18g with haltech platinum
Old Aug 28, 2014 | 08:20 AM
Conway_160's Avatar
Conway_160
Your running twins and your not at full boost untill 4.5k??
Old Aug 28, 2014 | 08:52 AM
aas350z's Avatar
aas350z
Yep, I checked compresion level and it is 116-119 psi on all pistons I have no idea why twins spool so late when I had OEM engine my turbos risen at 1,5k RPM
Old Aug 28, 2014 | 09:19 AM
Conway_160's Avatar
Conway_160
Have you pulled the turbos out and make sure they still spin freely?
Old Aug 28, 2014 | 09:41 AM
steven350's Avatar
steven350
Have you drove it on the streets yet? Any overheating issues? Hot start issues?
Old Aug 28, 2014 | 11:11 AM
aas350z's Avatar
aas350z
I didnt check turbos before build, my mistake but turbos are rather ok, no signs of oil everything is dry and they stable holds boost, besides this no any over issues. I track this car rather often mostly drift but time atack as well and no problems with overheating i have oil cooler. Coold start depends on proper tunning, correction settings additionally I increase RPM to 900 and works perfect
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
