My 400hp Project (56k beware)
Old Feb 1, 2004 | 12:37 PM
cwhit_5's Avatar
cwhit_5
soon to be 3 TT kits here in tx...im having mine installed starting this friday in austin.
Old Feb 1, 2004 | 03:08 PM
shaun_walsh's Avatar
shaun_walsh
Hi Spazpilot,
I also have TT kit with the Stillen "PIG" exhaust . I am curious what you are expecting the ECU Mod to help you with? What are the goals?
Shaun
Old Feb 1, 2004 | 03:29 PM
t32gzz's Avatar
t32gzz
Originally posted by daking350
Very well thought out man..I had the INJEN and its TOOOO Fart can sounding..The Stillen is a really good Design for Free flowing,But man are you right about it being a PIG!!!I think is 41 lbs MORE than the stock or something like that..
IMO the Borla is the best option..Sounds good,looks good,not heavy..I mean after all why not trust the guys that just do exhaust parts,all the domestic guys cant be wrong!!
Hey isnt Skiddazzle from TX too??That means TX is gonna have 2 TT beasts???NOT FAIR man!!Good luck and cant wait for the Dyno's!!!
3 TT's in TX, and one has 450 RWHP, dynos tomorrow!
Old Feb 1, 2004 | 05:04 PM
TXREFI's Avatar
TXREFI
Originally posted by spazpilot
Max thanks for hooking me up were to go for those 380 injectors. Hoping for good numbers on the dyno and the track.
Sweet Set Up Spaz, I am over in Frisco. Are you doing the install yourself? Need any help?
My daily driver G35 needs this set up.
Old Feb 1, 2004 | 05:31 PM
spazpilot's Avatar
spazpilot
Originally posted by shaun_walsh
Hi Spazpilot,
Shaun
Shaun
I am not sure if you are aware of this but our TT kit came with no kind of timinig fix. I am not planning on keeping my kit at the 5.7psi boost, so I had to address this issue. Instead of running ecu upgrades and adding a piggyback with a new remap, I decided to let some experts do my tuning. I went out and bought a set of the 380cc injectors and will run TS turbo ecu for fuel and timing for a 8.0-8.5psi setting. Once installed and running I will make a long car drive there and have them fine tune it. I am not big on cutting harnesses for injectors or the emange if I can go a cleaner route. Its simpler and less likely for stuff to go wrong. Everthing may change if I can't get this to work but my goal is to run a low 400rwhp. Please do talk to your tuner if you decide to go with more boost. There is no timing adjustment and the kit could get as ugly as the ati kit if your planning on boosting much above 6psi. CJ
Old Feb 1, 2004 | 05:35 PM
spazpilot's Avatar
spazpilot
will be doing the install myself. Hopefully will start on tuesday after I dyno the car at 21st century muscle car in carrolton for a base dyno and the redyno at the same shop after all is complete.
Old Feb 1, 2004 | 05:38 PM
spazpilot's Avatar
spazpilot
I smell a meet once we all get setup. I saw mike's car at stonebriar mall about a week ago. It looked gooood Your doing the same fuel setup as his right?
Old Feb 1, 2004 | 05:53 PM
TXREFI's Avatar
TXREFI
Spaz, Do you have a estimated cost of labor and materials?
Old Feb 1, 2004 | 05:59 PM
spazpilot's Avatar
spazpilot
Labor = 0.00 I will do all the install
Parts = 9085.00 for ecu, injectors, turbo kit, pullies, exhaust, cats, and FMIC
Old Feb 1, 2004 | 07:52 PM
fluidz's Avatar
fluidz
Default OMG
You have my dream.........**** im wet...........hold on......brb
Old Feb 1, 2004 | 07:53 PM
supra crazy's Avatar
supra crazy
I was thinking about installing my turbo kit if i ever get one how hard do u think its is gonna be and do u have a hydralic jack or somthing? because installing test pipes was a ***** with floor jacks.
keep us posted please.
Old Feb 1, 2004 | 08:17 PM
spazpilot's Avatar
spazpilot
Sorry no hydrolic lift just jack stands. As for how hard, I will let you know. I have experienced with turbos on my 97 eclipse turbo, but I know this car is a different beast. from the instructions doesn't seem to bad if you know what you are doing. Good thing is that I do have lots of tools including an air compressor for the bolts that don't want to come off easy
Old Feb 1, 2004 | 11:19 PM
350Now's Avatar
350Now
Good luck on your install, you have lotsa of goodies over there. I'm also doing my install on my own and it's a pain in the ****... The engine bay is so tight and hard to manuever around. But luckily, I think I got most of the hard stuff done. The turbo manifolds, turbos, wastegates, down-pipes, new oil pan are all up and now it's only a matter of the piping, wiring the the e-manage and hanging the FMIC.
I'm keeping the 420cc RC injectors and too bad they didn't make it fit to the stock wiring harness. Such a pain to cut and solder a new harness.
I will also be keeping the e-manage for now. I will enjoy the 5.6 psi for a while then work on pushing more boost. I think I will be happy when I have 400 RWHP but only time will tell.
Additional stuff i'm putting in:
Nismo catback
NGK Iridium
Blitz Turbo Timer
I agree that if you are planning to boost higher level please everyone look into some sort of timing control.
Old Feb 2, 2004 | 01:38 AM
XBS's Avatar
XBS
Veteran
why did u change the injectors to small ones? wont they be running on a higher cycle than the Rc ones? just wondering i guess i missed something thanks
Old Feb 2, 2004 | 04:54 AM
TXREFI's Avatar
TXREFI
Did you buy all the pieces from one supplier?
Old Feb 2, 2004 | 07:35 AM
etx's Avatar
etx
Hey are those resonated test pipes or high flow cats? How much were they?
Old Feb 2, 2004 | 08:23 AM
elektrik_juggernaut's Avatar
elektrik_juggernaut
Man, i'm so jealous!!!.......turbo kit and air tools!!!........dammit!!!!.......i'm gonna go kick my cat out of spite!
Old Feb 2, 2004 | 09:35 AM
  #38
spazpilot's Avatar
spazpilot
XBS:
wanted to run the TS ECU upgade and they don't have a map for the 440 injectors. Also trying to not chop up my wire harness.
TXREFI:
Bought every single product from a different supply. It was who ever was cheaper
etx
High flow cats made by Random Technology. You can get them at Performance Nissan
Old Feb 5, 2004 | 04:42 PM
  #39
nwdriftking's Avatar
nwdriftking
i though that the greddy kit came with rc440 injectors, so why would you need pe injectors?
Old Feb 5, 2004 | 04:45 PM
  #40
nwdriftking
didn't read previous post.
