turbo coolant lines
Old Apr 13, 2014 | 04:24 PM
joshua350z6841's Avatar
joshua350z6841
Default turbo coolant lines
ok i have a gtm twin turbo kit an the oil lines are simple. an the coolant lines i am lost at. from what i gather u put the t fitting in the hoses going into the heater core on both left an right side. an that is the feed lines but it dose say were to run the coolant drain lines any help would be great.
Old Apr 13, 2014 | 06:20 PM
joshua350z6841
from what i can tell u just link the two turbos.
Old Apr 13, 2014 | 06:30 PM
Recklezzz's Avatar
Recklezzz
I went from drivers heater hose to drivers turbo inlet. Then drivers turbo outlet to passenger turbos inlet. Then outlet to passenger side heater hose. Never had a problem. As long as there is a pressure differential you will be ok. In this case the heater core is the pressure differential.
Old Apr 13, 2014 | 06:32 PM
Brolan04z's Avatar
Brolan04z
Correct^^^^
Old Apr 13, 2014 | 06:41 PM
joshua350z6841
awesome thanks guys
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
