Gauges and e-01 install pics
Old Feb 3, 2004 | 08:36 AM
Chebosto's Avatar
Chebosto
whoa!
that's crazy! do they just slip right into the stock gauge pod holes?
the stock console is one piece correct? the multi-function and battery and oil pressure are all one component, right?
cool install!
Old Feb 3, 2004 | 09:12 AM
Drag Limited's Avatar
Drag Limited
sweet
Old Feb 3, 2004 | 10:10 AM
ACP's Avatar
ACP
thanks everyone.
I Really like how they came out
Originally posted by Chebosto
whoa!
cool install!
Removing the dash part was pretty easy.
I used the write up
Here
The gauges I just pushed in and screwed from behind as far as I could get them. There is a small gap, because of the Defi bezel ring, but not noticable.
Nothing is needed to keep them in place, because it is that tight.
All the stock gauges are connected as one piece. There is actually 2 circut boards. I wanted to JUST install the multi-function gauge, lcd screen on the dash by itself, but having the other parts of the circut board connected means I needed a bigger space to mount it, so I haven't come up with any place yet..
and the e-01....
Man, lucked out. The screen and control fit PERFECT in the Nav space. Just wedged in there, and they do not move, unless you put some goood force on one side, to get it to start working out.
So both parts of that install went pretty smooth.
Old Feb 3, 2004 | 10:18 AM
ACP's Avatar
ACP
The circut board on the right, is the one with the mulit-function lcd screen that I want to mount, The board is 5 3/4" long by 2 1/2 thick
Haven't found a good spot where I could put that yet, with that amount of space
Old Feb 3, 2004 | 10:31 AM
JeffR116's Avatar
JeffR116
Nice! I definitely like those gauges you have there. The start-up/shutdown sequence is sweet. And they're totally black!? Bad@$$.
IMO, I personally would not mount them as a replacement to the stock gauges. I prefer the A pillar mount myself.
Old Feb 18, 2004 | 04:04 AM
ACP's Avatar
ACP
Just want to give alittle update on this, as I have been getting pm's on the subject
with the help from derek_i, we were able to take the stock gauges apart from the circut board.
Here are some pictures
click on images for larger view
Here is the little LCD screen
I still haven't found a location I like to relocate the LCD sceen, but I am thinking of the bottom of the RPM gauge, notching out a square in the gauge there, if there is room...
350Z_Al
Oct 29, 2020 07:44 PM
