GReddy Twin Turbo based 350Z
You can use the NISMO cams with FI. There is nothing saying that they are too big. The duration is fine, the lift is of course fine, and there are no overlap numbers out that I have seen. They do not have a wild idle or anything and I don't see the problem. The JWT cams are ok with FI per JWT and other experts on the product. The NISMOs are more mild than the JWTs except for duration which is hardly more aggressive. Good luck with your list!
Ok, Cams back on the list.
Ok now, if I want to have a fully programmable ECU, what would you recommend? I saw this MoTeC but its too expensive, any other option do I have?
Thanks,
Az
Thanks,
Az
How much do those rods and pistons go for?
SGP Racing's pistons are 8.5:1 Boosted Forged Pistons they run $1,175...you can pick up XTP Pistons which are 8.5:1 Boosted Forged Rods for $775
Also what's the best deal you've all found on the Nismo exhaust?
Originally posted by JspecZ
SGP Racing's rods are "Pauter" they sell them for $1,175, I-M-Racing has the same rods for $1,039
You can pick up the Nismo exhaust for $900 through Performance Nissan
Originally posted by ZRAYGO
you may want to think twice about ordering from i-m racing. i know that thier prices are hard to beat, but i have been getting reactions from all competitors alike saying that thier customer service is jacked. Everyone seems to agree on this subject no matter who i speak to...from dealerships to specialty part stores. Everyone keeps telling me that if i spend a dime over there, that it may be the last time i see it. They say dont spend money over there unless you can afford to lose it. Just a thought.
If they are robbing people why are they still in business? someone should take car of that
Ill top that list off...
NGK Iridium Spark Plugs
MSD Ignition
JIC-Magic 3" Axle-back
JIC-Magic Y-pipe
Polished Intake Manifold
HKS SSQ BOV - 225
Power Enterprise Turbo Kit:
-PE1420 turbos
-Custom exhaust manifolds
-Custom front pipe (2)
-Custom high capacity aluminum oil pan
-Custom high capacity fuel pump
-PE injectors (6)
-Fuel pressure regulator
-Air intake – PE Air Impulse II (2)
-Air pipe set
-Oil line set
-PE gaskets
-PE overflow tank
Custom open wastegates (compliments to skidazzle)
Custom front mount air-to-water intercooler
Custom Test/Down Pipes
Tomei 264 Cams
Titanium Retainers
Bronze Valve Guides
?Ferra Valves?
?NISMO 46cc Heads?
?350EVO Throttle Body?
Apex'i S-AFC-II
HKS Type-2 Turbo Timer
TechnoSquare ECU
Aeromotive DMFU
Defi A/F & Boost Guages
XT-PRO 8.5:1 Pistons
Crower Billet Rods
Darton Sleeves
PE Boost Controller @ 12PSI
Fluidyne Radiator
Excedy Carbon-Carbon Twin Disc Clutch
Tilton Flywheel
Rogue Engineering Short Shifter (i guess)
BF Goodrich KDs
Tien Flex Suspension
Dream on right?
MSD Ignition
JIC-Magic Y-pipe
HKS SSQ BOV - 225
-PE1420 turbos
-PE injectors (6)
-Air pipe set
-Oil line set
-PE gaskets
-PE overflow tank
Tomei 264 Cams
Titanium Retainers
Bronze Valve Guides
?Ferra Valves?
?NISMO 46cc Heads?
Apex'i S-AFC-II
TechnoSquare ECU
Aeromotive DMFU
Crower Billet Rods
Darton Sleeves
Fluidyne Radiator
Tilton Flywheel
BF Goodrich KDs
Dream on right?
Originally posted by VQ35DES
?NISMO 46cc Heads?
Crower Billet Rods
?NISMO 46cc Heads?
Crower Billet Rods
They have such a good reputation that they get cars shipped from overseas for upgrades/tuning. They're almost done with a GReddy TT 350Z that they're working on for a guy in the middle east. The entire engine has been redone from the ground up. This beast will be putting out over 600 horses. I'll keep you updated.
Originally posted by G35_AutoX
Hey guys. I deal with SGP Racing all the time. They have excellent knowlegable people, great service and if you ask them, they'll price match most of these jokers that don't deliver.
Thanks,
Az
I may be wrong, but I don't think the Nismo clutch is going to last long with around 400 rwtq. Might want to check on that before you purchase and leave yourself room to increase the power later without having to get a better clutch 12-24 months down the road.
SGP has been doing Nissan cars for a while, so they are pretty reputable...
Originally posted by spazpilot
quick question. Why is it that you are wanting the greddy TT when in your sig it says you have the ultimate racing turbo kit ?
!! That was about a month ago.... and since then I have changed my mind
Originally posted by aalzuhair
Check it out GReddy 350Z TT It comes with 4
Originally posted by fluidz
I know one thing.........SAUDI ARABIA has one DIP SH*T person that lives there foresure. DUDE.....I have seen you post incorrect info all over this board, please learn things before you go blabbing about false stuff.
GReddy 350Z TT Site and read the notes IF YOU CAN READ
2nd, What's up your A$$.....
I will let you have one thing
Originally posted by g356gear
I know.I have no idea what I did to this guy….. I thought he might be someone young and filled with energy but to my surprise he is not……… Take it easy fluidz
And he has seen my "incorrect" info all over the board!!!!!!!!!! It was one post and I apologized to the guy who started the thread……. Like I’m out there posting incorrect info for some
Az
