GReddy Twin Turbo based 350Z
Originally posted by VQ35DES
Ill top that list off...
NGK Iridium Spark Plugs
MSD Ignition
JIC-Magic 3" Axle-back
JIC-Magic Y-pipe
Polished Intake Manifold
HKS SSQ BOV - 225
Power Enterprise Turbo Kit:
-PE1420 turbos
-Custom exhaust manifolds
-Custom front pipe (2)
-Custom high capacity aluminum oil pan
-Custom high capacity fuel pump
-PE injectors (6)
-Fuel pressure regulator
-Air intake – PE Air Impulse II (2)
-Air pipe set
-Oil line set
-PE gaskets
-PE overflow tank
Custom open wastegates (compliments to skidazzle)
Custom front mount air-to-water intercooler
Custom Test/Down Pipes
Tomei 264 Cams
Titanium Retainers
Bronze Valve Guides
?Ferra Valves?
?NISMO 46cc Heads?
?350EVO Throttle Body?
Apex'i S-AFC-II
HKS Type-2 Turbo Timer
TechnoSquare ECU
Aeromotive DMFU
Defi A/F & Boost Guages
XT-PRO 8.5:1 Pistons
Crower Billet Rods
Darton Sleeves
PE Boost Controller @ 12PSI
Fluidyne Radiator
Excedy Carbon-Carbon Twin Disc Clutch
Tilton Flywheel
Rogue Engineering Short Shifter (i guess)
BF Goodrich KDs
Tien Flex Suspension
Dream on right?
MSD Ignition
JIC-Magic Y-pipe
HKS SSQ BOV - 225
-PE1420 turbos
-PE injectors (6)
-Air pipe set
-Oil line set
-PE gaskets
-PE overflow tank
Tomei 264 Cams
Titanium Retainers
Bronze Valve Guides
?Ferra Valves?
?NISMO 46cc Heads?
Apex'i S-AFC-II
TechnoSquare ECU
Aeromotive DMFU
Crower Billet Rods
Darton Sleeves
Fluidyne Radiator
Tilton Flywheel
BF Goodrich KDs
Dream on right?
People are also gonna be needing new cranks as well as they aren't really up to high-boosting chores.
Oh, and you don't need the DFMU or the afc if you're gonna run the technosquare ECU.
And with all that you better be running more than 12lbs. Don't forget you're lowering compression. And with the built motor you're looking at more like 20+ lbs. And lots of fun.
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
hardkicks
Sep 20, 2015 12:28 PM
