NEW Vortech V7 YSi with Redesigned Billet Impeller
Old May 20, 2014 | 04:29 PM
OldManZ350's Avatar
OldManZ350
Default NEW Vortech V7 YSi with Redesigned Billet Impeller
http://www.dragzine.com/tech-stories...-supercharger/
Attached Thumbnails NEW Vortech V7 YSi with Redesigned Billet Impeller-mg4_9703-custom.jpg
Old May 20, 2014 | 09:42 PM
350z006's Avatar
350z006
Hmmm...so since the new impeller is billet vs the original cast, does that mean the impeller will be lighter and hence easier to turn (ie less belt slip)?
Old May 21, 2014 | 10:23 AM
str8dum1's Avatar
str8dum1
same aero technology as all the new turbos. Just means it can be cut at more aggressive angles to make them more efficient.
doubt it will result in less belt slip. Def not a reason to swap to the new design.
Old May 21, 2014 | 09:05 PM
OldManZ350's Avatar
OldManZ350
IMO the only way to do it right is with a,
1. 10 Rib Serp or 36mm wide Cog on the Drive Belt.
2. Revise the Jackshaft Assy to utilize a wider Cog Belt 36mm wide min.
3. Radius Rod Kit
This is all doable, just a matter of working out the Design.
Old May 22, 2014 | 02:36 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Weight of the impeller is negligible when talking the load on the engine/belt slip.
Calinismo350z
Sep 14, 2015 04:04 PM
Quamen
Jun 24, 2009 01:46 PM
ryan350z
Jan 31, 2005 11:33 AM
