How much heat wrap will I need?
Old May 30, 2014 | 11:18 AM
2one8's Avatar
2one8
Default How much heat wrap will I need?
Looking at this stuff, http://www.jegs.com/i/DEI/186/010110...ductId=1993466 Wondering how much I am going to need to do all hot and cold pipes on a Powerlabs Single setup? Says it comes with 2 50 foot rolls, which sounds like a lot, but I know how fast that stuff can go. The cold pipes I have already have that reflective yellow stuff which is fine, but I dont like how bright it is, and I like how it looks when wrapped with the DEI stuff. I came across a supercharged Z a few weeks back that had all pipes wrapped in this and it looked good and kept the engine bay clean and serious looking.
Old May 30, 2014 | 11:57 AM
iideadeyeii's Avatar
iideadeyeii
One 50ft roll wont be enough to even do all of the exhaust.(TN kit) That's all I can help ya.
EDIT Also make sure it's titanium exhaust wrap. The one that works to 2000 degrees. I've had other types burn off on me
Old May 30, 2014 | 09:08 PM
bealljk's Avatar
bealljk
I dont know the power labs kit that well but I would think 100ft of 2" would be enough. I would get a 1" roll of 50' to wrap your headers. A thinner wrap will contour the curved pipes better than a 2". I would use whatever you have left over to wrap your headers/exhaust as far as it'll go back. I got 6 rolls and had about 2 rolls leftover, so I did my bikes headers/exhaust.
I would also ditch the metal ties that DEI provides and use a thick bailing wire or rebar tie wire, just make sure its not coated!!!
File Type: jpg
Old May 31, 2014 | 05:03 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
You can set up a quick excel spread sheet
Need to know:
PIPE OD
Pipe Length
Roll Width
Roll Utilization (accounting for overlap, say 25% loss, 75% utilization)
For example:
2.75" od pipe has a circumference of 8.635"
Thats .72' of wrap to make one revolution around the pipe
Lets say I have 2" wrap wtih 75% utilization, i get 1.5" per revolution
Lets say I have a 5ft pipe..thats 60"/1.5 = 40 revolutions
40*.72 is about 29' of 2" wrap. You can play with the numbers to get your self an estimate.
so the formula would be:
(pipe outer diameter * pi/12 * pipe length inches/(roll width * utilization))/12
Which results in feet of wrap needed.
Old May 31, 2014 | 06:12 AM
bealljk's Avatar
bealljk
DEI has this webbased calculator ... probably going to get you as close as anything...
http://www.designengineering.com/nit...wrap_calc.html
Old May 31, 2014 | 06:54 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
the beauty of xcel is you can make a list of pipes, determine a length for each and sort them so you can buy your spools of wrap in the right lengths.
Also you can save a nice offline copy and adjust for each pipes characteristics.
Old Jun 1, 2014 | 08:35 PM
Z_on_TE37's's Avatar
Z_on_TE37's
I wrapped my powerlabs kit. Every exhaust side pipe except the wastegate pipe since I'm open dump. Took me 2 rolls of 2x50 and was just enough. You'll need the long ss ties for most of the piping. Silicone spray it all afterwards, do not leave it raw. If u need anything else ask me, been there and done that with that kit. Good luck
Old Jun 2, 2014 | 06:02 AM
2one8's Avatar
2one8
sweet thanks. I might just run as is for now and wait until this winter and send everything in to get ceramic coated instead.
Old Jun 2, 2014 | 01:54 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
So have any of you guys actually seen a decrease in life of your headers (exhaust) after you wrapped them?
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
