PSA: When building your custom fuel system you should....
Old Jun 23, 2014 | 03:02 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Default PSA: When building your custom fuel system you should....
Leave some fuggin slack on the feed line to the rails.
Even with solid motor mounts there can still be flex and when you go to disconnect the rails you dont want the fittings to be in tension.
Simple concept right? One that a shop that cranks out race cars would know right?
Nope. My lines are .5" short from going back on the rails (rails mounted into lower intake manifold). Should have been about 2" for some flex.
Thanks CIN! Appreciate it.
Old Jun 23, 2014 | 03:47 PM
Resmarted's Avatar
Resmarted
LOL
I'm sorry to hear that man. Makes me feel better about how I did my lines LOL ghetto routed, with nice slack.
Old Jun 24, 2014 | 09:49 AM
str8dum1's Avatar
str8dum1
all of my lines are taught when snugged down with the fittings.
if you feel they arent correct, have CIN redo them. I'm sure they will fix it if its a mistake.
Old Jun 24, 2014 | 11:14 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
my car will never breach the doors of cin again. too bad I wasted time and money while I was too busy to diy...lesson learned I suppose.
The line is short plain and simple. When you cannot remove and reinstall the fitting because it is too short then you have an issue. any flex between engine and line and something is going to snap.
Old Jun 24, 2014 | 01:11 PM
djamps's Avatar
djamps
sucks to hear man.
wouldn't mind my FPR being somewhere other than smack in the middle of the firewall transmitting fuel system sounds into the cabin. At least with an un-damped fuel system, it sounds like a diesel inside the car compared to any other mounting spot.
Old Jun 24, 2014 | 01:19 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Yup. Must have tied into the rails and then ran the line to the rear bucket and pulled it good and tight.
Also didnt install it like i wanted. I wanted to Y into the rails and Y out so that they were parallel rather then series but i got the ole " we build racecars, this is how we do it on them" line.
Nothing like having a very large feed line that just reduces into the rail..what a waste.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
