Power Enterprise TT: difference between Japanese Spec and USA Spec
Old Feb 4, 2004 | 04:39 AM
aalzuhair's Avatar
aalzuhair
Lightbulb Power Enterprise TT: difference between Japanese Spec and USA Spec
Does anyone the difference between Japanese Spec and USA Spec Power Enterprise TT?
Thanks,
Az
Old Feb 4, 2004 | 04:41 AM
Juztin's Avatar
Juztin
Piping I believe is all, otherwise the intial power levels boasted by the kits might vary due to normal consumers having their "high ocatane" fuel rating to be what...110 octane?
--j2
Old Feb 4, 2004 | 06:30 AM
spazpilot's Avatar
spazpilot
also the exhaust manifols, set up for left hand steering
Old Feb 4, 2004 | 06:39 AM
aalzuhair's Avatar
aalzuhair
ohhhhhhh, yah forgot about that. True, then I guss it would be the piping and exhaust manifolds.
Thanks guys
Az
Old Feb 4, 2004 | 10:00 AM
Chebosto's Avatar
Chebosto
THe US spec PE TT is the same as the J-spec TT kit.
originally the IC piping was different, as well as the exhaust manifolds. but after doing the R&D for the US kit, it was discovered that the US pipes would fit on the Jspec Z and hence cheaper to manufacture- there is basically no difference in the two versions now.
the PE team actually went against a USpec pipe design for the IC -> TB, the proto was actually very straight and 4" diameter to maximize flow and replace the MAF sensor's bracket (that black cylinder with the sensor attached to it.. the sensor you can remove), the Jspec version (and now the production US version) keeps the stock MAF sensor bracket and has bent pipes to fit in the engine bay. poo! the straight to the air to the TB. the better!!
hope that clarifies ..
Old Feb 4, 2004 | 03:33 PM
zillinois's Avatar
zillinois
Is the PE kit shipping yet? If so, has anyone installed?
Old Feb 4, 2004 | 04:04 PM
Chebosto's Avatar
Chebosto
last year's allotment was sold out.. there are 5 kits currently out there some where... a few popped up on ebay. so i dunno if they've actually been installed..
Big Bad Black Track has it... i DID have it... will soon. hopefully...
Old Feb 4, 2004 | 05:46 PM
Guru's Avatar
Guru
They are available currently.
Old Feb 5, 2004 | 11:32 AM
articfury's Avatar
articfury
Charter Member #55
Cheston,
Are you going to put the Proto US-spec piping on your car, when/if, you get the setup?
Would TS be allowed to sell the other version of the piping as their own "upgraded pipe kit"? Just a thought...
D
Old Feb 5, 2004 | 03:58 PM
Chebosto's Avatar
Chebosto
they can build the Intercooler To Throttle Body pipe separately if someone chooses to buy it.. it will also have a hole for a BOV too...
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
