PLEASE HELP! limp mode, turbo overspooling
Old Aug 1, 2014 | 05:35 PM
Speednz's Avatar
Speednz
Great news! I did some data logging on my way home and came to the conclusion it is 100% my A/F ratio that is causing the issue. It idles and revs in the 13.5-14.8 range but literally the second i hit 1psi of boost it drops to... wait for it.... 10!!!!! No wonder my car literally stalls when i build boost.. its flooding.. now i just need to figure out if its my MAF or the tune...
Old Aug 1, 2014 | 07:22 PM
djamps's Avatar
djamps
Oil blowing on the MAF will cause that.
Old Aug 1, 2014 | 07:23 PM
cashmoney03's Avatar
cashmoney03
JB Weld is not for turbos.
Old Aug 1, 2014 | 08:09 PM
Speednz's Avatar
Speednz
so new housing it is. will be ordered tomorrow
Old Aug 25, 2014 | 05:25 PM
Speednz's Avatar
Speednz
Okay guys got new housing and it ran for a day fine then started smoking again. Took it apart and once again the hot side gasket was blown. So replaced it and worked for half a day and smoking again. So I'm thinking I have a issue with my oil return system. I'm using a boost doctors pump to get it back to my oil pan. All the lines are braided stainless steel and I know I used -4 (1/4) for feed line and (5/8) I forgot if that's -10 or -8 but that should be good right? I know some people don't even use return pumps.. is there any way to reduce oil pressure?
Old Aug 26, 2014 | 06:27 AM
iideadeyeii's Avatar
iideadeyeii
Oil feed restrictor plate
Old Aug 26, 2014 | 06:32 AM
Speednz's Avatar
Speednz
Well i mean the oil feed fange on my turbo has a hole the size of a needle.. so im not sure how its even possible i could be gettng too much oil pressure in my turbo when the hole is that small
etkms
Jun 19, 2022 06:30 PM
Vigman
Nov 17, 2015 04:34 AM
