Is it o.k.
Old Feb 6, 2004 | 06:57 AM
myGthang's Avatar
myGthang
Default Is it o.k.
Is it o.k. to run an ati sc, crawford intake, ur pullies, borla ext, rt cats, assuming i have bigger injectors and new ecu? I've seen sc without intakes and ur pullies...any reason why? Thanx in advance... the reason i ask is due to the fact i want to get every possible bolt on before going sc...
Old Feb 6, 2004 | 07:47 AM
TheBigShow's Avatar
TheBigShow
the ati will come with it's own intake piping. plus, crawford makes an intake plenum; not intake. u will need a smaller belt to fit on the ur pulley than the one that comes with the kit, also. the ur crank pulley has a smaller diameter than the stock one, which the kit is designed to use.
Old Feb 6, 2004 | 08:07 AM
myGthang's Avatar
myGthang
So it is o.k. to run the crawford "PLENEUM" and the ur pullies?
Old Feb 6, 2004 | 08:09 AM
TheBigShow's Avatar
TheBigShow
i don't see why not.
Old Feb 6, 2004 | 08:18 AM
VandyZ's Avatar
VandyZ
I would not run pullies with Nitrous or any Forced Induction, but that’s just me. Too much risk with no dampening on the crank pulley.
Old Feb 6, 2004 | 11:14 AM
350zdanny's Avatar
350zdanny
I agree, without the damping, some knock sensors have been known to go off.
Dan
Old Feb 6, 2004 | 11:32 AM
myGthang's Avatar
myGthang
Dan
so it's o.k. to run the crawford rather than the ur pullies...cool thanks guys
Old Feb 6, 2004 | 10:14 PM
MY350Z.COM's Avatar
moved
Old Feb 6, 2004 | 10:39 PM
daking350's Avatar
daking350
You cant run the UR pulleys on the SC unless you want to loose boost..The sizing screws you up..
Old Feb 7, 2004 | 06:52 AM
12SecZ's Avatar
12SecZ
I am running the Crawford with the ATI just fine, more even air flow, tuning is required to keep it fat, I also have Borla and RT, same thing applies tuning tuning tuning.
Old Feb 7, 2004 | 07:58 AM
daking350's Avatar
daking350
Lets make sure he counts those teeth on the puleys too..lol..
Old Feb 7, 2004 | 08:42 PM
12SecZ's Avatar
12SecZ
Did you get yours on , what were your final boost numbers and pulley teeth count and Bill's (Ravas?)
It would help all of us ATI guys to post that info, thanks. SWeeing how so many different pullies and boost levels are floating around.
Old Feb 7, 2004 | 08:47 PM
daking350's Avatar
daking350
Got them on..Waiting for my belt to come as well as a BOV...Then its a trip to mr Bob Ida to get the Perfect Powere SMT6 installed and tuned...Probably by next Friday/Sat.
Check out this link!!!
...http://www.**********.com/forums/inde...wtopic=209&hl=
jungleson
May 12, 2010 11:38 AM
craigo'sznprgrs
Nov 23, 2007 05:00 PM
quiksilver149
Aug 14, 2007 05:32 AM
