Power steering radiator relocation
Old Feb 9, 2015 | 11:49 PM
TougeMonster's Avatar
TougeMonster
Default Power steering radiator relocation
Hi guys i recently bought a used Vortech setup and im getting ready to install the kit. Ive read the instructions over and over and have the necessary means to get the kit installed right. However i am lost on how to properly relocate the power steering radiator. Its not much of a relocation but the instruction are not very clear on how this is done. Is there a DIY or something that i can get to move the power steering radiator onto the main radiator without any possibility of it falling off? Please post pics if you can, that would help me alot. Thanks guys
Old Feb 10, 2015 | 06:02 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
they make these special straps that go through the fins of both radiators and then you snug them up. That is what holds the psr to the radiator.
Old Feb 10, 2015 | 12:59 PM
MonkeyMagic72's Avatar
MonkeyMagic72
If you are lost on just the ps cooler relocating diy. It might not be to wise to attemp install the supercharger yourself as diy.
Old Feb 12, 2015 | 12:21 PM
str8dum1's Avatar
str8dum1
you can move it anywhere. You can buy new hose of any length and mount howver you want.
Old Feb 12, 2015 | 02:13 PM
- bigc -'s Avatar
- bigc -
^ what str8dum1 said. the vortech instructions aren't clear because the routing of power steering lines varied across model years and trim (at least for the G35s it did). just find a convenient place for the cooler where it will get air flow then run your lines there. cheap P/S hose can be picked up at O'Reilly/Kragen/Napa/Autozone - you won't need much.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
SharX59
Sep 30, 2015 10:54 AM
