Procharger setup - rpm hesitate slightly on acceralation when boost kicks in
Old May 9, 2015 | 07:31 AM
NeoGixxer's Avatar
NeoGixxer
Default Procharger setup - rpm hesitate slightly on acceralation when boost kicks in
Hey guys,
Quick question, Got a procharger tuned etc. Recently I noticed that my car would hesitate slightly on accelerating. Its a slight hesitation while the boost kicks in at 3,000 rpms. Enough to cause the wheels not to spin out (chirp I guess u could say) in 2nd or 3rd.
I never changed the coil packs and the car has bout 83,000 miles. I was wondering if it could be that? also I have no check engine light on? would a coil pack trigger that?
Old May 9, 2015 | 10:26 AM
jdm-v35's Avatar
jdm-v35
Sounds like a hiccup in the tuning or belt slip
Old May 9, 2015 | 01:51 PM
NeoGixxer's Avatar
NeoGixxer
Could it be a bad coil pack too?
Old May 9, 2015 | 02:19 PM
OldManZ350's Avatar
OldManZ350
Based on what you said, Sounds like tuning to me.
What happens if you only give it 1/2-3/4 throttle in boost?
Old May 9, 2015 | 04:36 PM
jdm-v35's Avatar
jdm-v35
more than likely not a coil. it is most likely tuning, or at higher rpm the procharger cog belt can skip teeth causing it to run rich for a second and hesitate.
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
